Omni brake pots Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » April 2011 » Omni brake pots « Previous Next »
Mel La Plante (Mel_4104)
Username: Mel_4104
Post Number: 160
Posted From: 173.180.124.202
Posted on Tuesday, April 12, 2011 - 7:16 pm:
Are any of you using Omni brake chambers on your buses and if so what do you like or dislike about them. i am going to change out the rears on my 4104 and go to the 30/30 instead of the mini max that i have at present. thanks for any and all answers both good and bad about them and what you would use... thanks Mel 4104
Username: Luvrbus
Post Number: 1089
Posted From: 74.33.51.199
Posted on Tuesday, April 12, 2011 - 10:18 pm:
They are good spring brakes I never used Omni because of the price difference in Omni and the others like MGM, Haldex,Anchorloc and others good chambers that is about all you see on the Featherlite Nascar trailers
good luck
Brian Evans (Bevans6)
Username: Bevans6
Post Number: 27
Posted From: 65.92.50.157
Posted on Wednesday, April 13, 2011 - 9:13 am:
What is the difference between an Omni and a "standard" spring brake chamber such as a Haldex or a Bendix?
Brian
Username: Luvrbus
Post Number: 1090
Posted on Wednesday, April 13, 2011 - 9:58 am:
For a long time and I don't know if it has changed with the others are not but Omni was the only sealed spring brakes.I don't know for sure if they are better than the others but if they haven't come down in price they sure cost more for certain models
good luck
Username: Chessie4905
Post Number: 2066
Posted From: 71.58.71.157
Posted on Wednesday, April 13, 2011 - 4:51 pm:
The big spring clamp ring is now crimped on, I believe all models, so the common, easy to find brands are the ones to get. They are surprisingly cheap because every truck uses them.It's nice that they will fit on a 4104, opposed to the newer GM models.Maybe one of these days, someone will come out with a shorter version that we can replace the DD3's with; and assorted plumbing that goes with it.Or new DD3,s at an affordable price.
