RV refrigerator Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » April 2011 » RV refrigerator « Previous Next »
Bill Holstein (Billmoocow)
Username: Billmoocow
Post Number: 143
Posted From: 71.59.162.64
Posted on Wednesday, April 20, 2011 - 7:22 pm:
Just put a new cooling unit on my propane fridge. What a PITA! Anyway, i have heard the real demise of these units is not using them. That somehow when they are not being used, it causes rusting and pitting on the coils. Is this true? Should i leave it plugged in at all times to keep the longevity or is it going to happen anyway?
Username: John_mc9
Post Number: 1200
Posted From: 74.162.95.135
Posted on Thursday, April 21, 2011 - 8:23 am:
Bill -
Re:
"rusting and pitting on the coils"
The metal generally rusts from condensation on the coils,
and there shouldn't be too much condensation when the
unit is off, right?
When we were full-timing (in an RV), the new cooling coils rusted
within a year of being in Florida; not all the way through, but
enough to be noticed.. Then again, the brake lines rusted through
after a year down here also.
A new cooling unit we were given, had sat for years in storage
prior to us getting it. It looked like new and preformed perfectly.
I doubt either running it or leaving it off will make much difference,
but there might be less condensation leaving it off....
John
Username: Jackconrad
Post Number: 1400
Posted From: 75.203.59.174
Posted on Thursday, April 21, 2011 - 3:19 pm:
Since the coils are the condenser part of the unit, wouldn't they be warm/hot when operating? (and the evaporator part inside the refrigerator the cold part of the unit) Since condensation forms when the surface is below the dewpoint, keeping the unit running should keep the coils above the dewpoint and prevent condensation from forming. Jack
Post Number: 1344
Posted From: 71.55.178.71
Posted on Thursday, April 21, 2011 - 5:37 pm:
They use amnonia for refrigeration instead of freon. The chemicals when under working conditions are the same effect. Taking hot air and putting it in a unwanted space. The problem is they have water in them also. and made of steel as they are will rust out regardless of where you are. They have rebuilt units available and they are about 1/2 price of a new unit. They are a bear to change sometimes you have to install it in the unit. They way to make sure the unit is bad is as follows.
remove unit from wall.
turn upside down for 24 hrs if possible
lay on one side for 6 hrs
lay on opposite side the same
lay on back the same
upright unit,and hook up a/c and check coils for heating, They will get real hot BE CAREFUL!! the element is normally about 150-150 watts at 110 v.
Gomer
