4106 motor mount opion sought. Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » April 2011 » 4106 motor mount opion sought. « Previous Next »
Tom Phillips (Fortyniner)
Username: Fortyniner
Post Number: 37
Posted From: 66.93.216.253
Posted on Thursday, April 21, 2011 - 8:50 pm:
How do these motor mounts look? The 4106 Im messing with has a lot of vibration on fastidle. Dont see any place obvious that might cause it.
Tom P.
4106 rear motor 4106 front motor mount
Username: Dallas
Post Number: 501
Posted From: 98.20.55.33
Posted on Thursday, April 21, 2011 - 9:46 pm:
To me the mounts look good.
If you have a vibration, look into having the rack run. you may have a bad injector or two. or three.
Besides, I don't think Detroits run well when wearing the Caterpillar Halloween costumes.
Post Number: 1345
Posted From: 71.55.178.71
Posted on Thursday, April 21, 2011 - 9:56 pm:
Tom; I had an 06 and found that from time to time I would have to check the bell housing for loose bolts. Also you may have a flywheel coming loose.
Gomer
Post Number: 38
Posted on Thursday, April 21, 2011 - 11:41 pm:
Great, first its a caterpillar now it has loose nuts. Running the rack is easier than checking flywheel so I guess Ill start there.
Thanks !
Post Number: 2073
Posted From: 174.91.144.16
Posted on Friday, April 22, 2011 - 6:42 am:
Fortyniner, I do believe that you have got this board and its inmates well figured out!
Post Number: 1347
Posted on Friday, April 22, 2011 - 8:47 am:
Tom You are fitting in just perfect LOL GOOD ONE
Gomer
Bill Gerrie (Bill_gerrie)
Username: Bill_gerrie
Post Number: 493
Posted From: 216.198.139.38
Posted on Friday, April 22, 2011 - 10:58 am:
Tom
Motor mounts are generally good unless they get oil soaked. Dal is probably right on when he says to look for a bad injector and maybe the halloween costume has a lot to do with it as well.
Bill
Brandon Merritt (Brando4905)
Username: Brando4905
Post Number: 37
Posted From: 50.55.221.225
Posted on Tuesday, April 26, 2011 - 9:20 am:
Tom,
Check the bulkhead for cracks also, had mine repaired recently and the vibes at fast idle went away.
