PeterE (64.50.1.99)
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 22, 2004 - 11:14 am: | |
I ran into a glitch with a bad pump last weekend so I am making a new go at it now. I decided to mount the pump next to the tank. I discovered that the pipe from the pickup is 5/8”… it is 3/8” at the firewall/bulkhead. Question: any reason that I should not use ½” from the tank, thru the pump manifold, and back to the original 5/8” at the tank? Flared pipe is new to me, always on a learning curve here. Thanks, Peter |
BrianMCI96A3 (198.81.26.45)
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 22, 2004 - 2:29 pm: | |
Refresh my memory, this pump is only going to be used as a primer pump? If the answer is "yes" then, as long as your connections are all tight (and without leaks), I can see no problems with it. Brian |
Peter E (Sdibaja) (64.50.1.99)
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 22, 2004 - 3:24 pm: | |
Brian... the pump and manifold will be alongside the tank This plan will have me using about 10' of 1/2" (and fittings, ball valve, etc.) between the tank and the existing 5/8" pipe... I can see no problem either, the other end gets down to 3/8” at the primary filter. Peter |
BrianMCI96A3 (65.40.154.171)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 23, 2004 - 10:26 am: | |
Should be fine then, Peter. Brian |
