Marvin (65.35.116.113)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 31, 2004 - 9:09 pm: | |
. Has anyone used a synthetic composite instead of the normal plywood sheeting for bus flooring . I have been told that this stuff is 1/3 the weight of plywood and 10 times as strong . 20 sheets of 1/2" or 3/4" plywood used in a 45' bus floor would save a huge amount of weight and help with the axle loading weights . Prevost uses a double layer of 3/4" plywood with a layer of lead foam insulation in between . Any thoughts or suggestions appreciated . . |
Nick Russell (66.82.9.65)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 31, 2004 - 10:48 pm: | |
We used 3/4 inch composite 4x8 foot fiberglass sheets over the original playwood in our MCI-8. Very strong, and much lighter. We got it from Engineered Bonded Structures in Elkhart, Indiana. Contact there is Ben Pearson, phone number is 574-266-3471. |
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 31, 2004 - 10:49 pm: | |
Oops, that would be plywood, not playwood |
Adame (129.82.52.236)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 31, 2004 - 11:53 pm: | |
A friend who works for a bus manufacturer here in Colorado gave me this name: Greenwood Forest Products. www.greenwoodproducts.com They make bus flooring which is 8 ply, 3/4". It has a flexible rubber layer between the third and fourth ply which seems to be meant to absorb vibration. I think they use one layer. |
James Maxwell (Jmaxwell) (66.81.61.132)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, February 01, 2004 - 1:24 am: | |
Don't know where u put 20 4x8 sheets in a 45' unless your doing the ceiling also. My 40' used 8 sheets on the floor, 5/8 t&g over 3/4 8ply marine. 25 sheets of 3/8 did all walls and ceiling. |
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, February 01, 2004 - 11:14 am: | |
. An on-going dialog with Prevost product managers and the engineers show that Prevost has considered the synthetic flooring , but they admit that the process to bring it to production could take 2 to 3 years . The use of synthetic flooring could save 1k lbs of weight - that translates into better fuel mileage , better braking , and increased cargo capacity if necessary. This would apply to any brand of motorcoach or RV . As bus converters , we face a major problem with axle weights and the new state rules that are now being enforced on some toll roads . Some states are now enforcing a 20k lb axle rule regardless of the capability of the axle . The current Prevost drive axle is 22.5k , but to be legal 20k is the max limit . I am documenting procedures to bring the final production weight well under current trends . The idea is to provide the same longevity with a big weight distribution and reduction . I have an approved conversion design that will scale at 43k wet . The Prevost GVWR is 54.5k . The use of synthetic flooring will bring this down to 42k ! |
