From DieselChat: setting boost on a 6... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » June 2011 » From DieselChat: setting boost on a 6V92T DDEC « Previous Next »
Post Number: 2088
Posted From: 174.89.178.140
Posted on Wednesday, June 01, 2011 - 9:26 pm:
Posted in DieselChat yesterday:
robnorthtriple: Does anyone know who can set the boost upon my '94 MCI with a 6/92T DDEC engine. I have a gauge on the dash panel and it shows 15lb of boost under load and a sit slows down climbing a hill, it drops to 12lbs of boost and 25 mph. I have fitted a new turbo. Thanks Rob North..
Username: Dallas
Post Number: 566
Posted From: 67.141.77.61
Posted on Wednesday, June 01, 2011 - 9:44 pm:
It sounds like there is an exhaust leak.
Look for any black marks anywhere from the manifolds to the hot housing.
ANY leak will cause a lowering of boost under load.
Username: Luvrbus
Post Number: 1133
Posted From: 74.33.60.241
Posted on Thursday, June 02, 2011 - 8:50 am:
sorry double post
(Message edited by luvrbus on June 02, 2011)
Username: Luvrbus
Post Number: 1134
Posted on Thursday, June 02, 2011 - 8:52 am:
Check for leaks then it could also be a bad boost sensor check the codes there is no adjustment per say only different turbos
good luck
Jim Shepherd (Rv_safetyman)
Username: Rv_safetyman
Post Number: 332
Posted From: 72.171.0.142
Posted on Thursday, June 02, 2011 - 9:30 am:
My thought is that it could be fuel restriction (filters or?) or air intake restriction (again filter). If it does not get enough fuel or air, the ECM can't make it build boost.
The other obvious problem, if it has one, would be a leak in the charge air cooler.
In an extreme case, it could be some sort of blockage of the exhaust system after the turbo.
So far, my experience with MAP sensors (in the early years of the DDEC, they used a GM MAP sensor), it is either good or bad but does not go slightly bad.
Jim Shepherd
Evergreen, CO
’85 Eagle 10/Series 60/Eaton AutoShift 10 speed transmission
Somewhere between a tin tent and a finished product
Bus Project details: http://www.rvsafetysystems.com/busproject.htm
Blog: http://rvsafetyman.blogspot.com/
(Message edited by rv_safetyman on June 02, 2011)
Username: Luvrbus
Post Number: 1135
Posted on Thursday, June 02, 2011 - 10:37 am:
Larry Jones just tricks his sensor so it will build boost on his DDEC I he couldn't get up his driveway the thing would not build boost or power now he runs around 20lbs all the time.
A 1994 model will probably not be a engine using the old sensors most of the III on the 2 strokes were up dated by DD
Tom Christman (Tchristman)
Username: Tchristman
Post Number: 294
Posted From: 66.218.33.156
Posted on Thursday, June 02, 2011 - 11:08 am:
Low turbo boost would be caused by dirty air filter or a restriction in the air intake, dirty fuel filter, leak in the exhaust system, plugged up muffler, worn injector tips, low compression, burnt valves, turbocharger that has tight bearings, etc. Should have a good mechanic look at it. You could simply remove the air intake from the turbo and exhaust from the muffler and see what that does on a short drive. Good Luck, TomC
Jim Sanders (Sandy)
Username: Sandy
Post Number: 53
Posted From: 69.199.96.250
Posted on Thursday, June 02, 2011 - 11:12 am:
Hi guys I have been wondering if a Boost>vaceum Gauge would give a driver some ideas of the load he was putting on a 6-92 T Dont know whether it is inter coled or not?????
Username: Luvrbus
Post Number: 1136
Posted on Thursday, June 02, 2011 - 11:21 am:
If it is a 6v92 TA it will be aftercooled a inter cooler will be on the outside of the radiator most of the time a boost gauge is good to have for driving the higher the boost means more fuel going through that puppy
good luck
George M. Todd (George_todd)
Username: George_todd
Post Number: 1239
Posted From: 99.37.28.23
Posted on Thursday, June 02, 2011 - 12:51 pm:
Technically, an intercooler is between the 1st and 2nd stages of a two stage air compressor. Both the engine mounted air-to-water cooler, and the radiator mounted air-to-air coolers do the same thing, and both are AFTER the turbo.
Turbo pressure is a function of the amount of exhaust being produced, which is a function of the amount of fuel being burned, and engine speed. So, turbo pressure will be greatest at nearly full governed RPM, with full throttle. As the governor moves the fuel rack to limit max. RPM, the turbo pressure will start to drop. As the engine slows down under a heavy load, it is making less power strokes, so it is producing less exhaust, so it produces less boost.
Partially dirty fuel filters won't let enough fuel thru under load, a dirty air filter won't let enough air into the turbo. An improperly adjusted throttle won't tell the engine to deliver full power.
No change in pressure over the old turbo?
If not, he replaced a good turbo, which wasn't the problem. As there is NO way to "set" boost, you set boost with your right foot, the low turbo output problem is elsewhere. What is the max. RPM setting? If its a DDEC, has the MAP sensor and wiring been checked? If the DDEC doesn't see enough turbo air pressure, it restricts the fuel input to avoid black smoke, so less boost and less power.
G
Username: Luvrbus
Post Number: 1137
Posted on Thursday, June 02, 2011 - 1:49 pm:
Waste gate turbo on the later 2 strokes were adjustable but you don't see many TomC has a waste gate turbo on a 8v71 but not the norm for a 2 stroke
Username: Dallas
Post Number: 570
Posted on Thursday, June 02, 2011 - 2:51 pm:
After all is said and done... I've looked at a lot of bus owners that complained of loss of boost. In about 90% of those cases, I found that either the exhaust manifold or the rubber tubing between the rest of the system was leaking. It didn't matter if it was DDEC or MUI....
But then again, I could be wrong.
Hint:
Make ABSOLUTELY certain there is no exhaust leak anywhere.
Username: Pete_rtsdaytona
Post Number: 661
Posted From: 184.88.99.113
Posted on Thursday, June 02, 2011 - 2:54 pm:
Make sure you have the right TBS (Turbo Boost Sensor)
D/D old# - 16070629
D/D new# - 23528418
or
GM old# - 1219935
GM new# - 28182633
or
Delphi# PS10083
These are all TBS's with a 3 BAR range 70-300kPA
There are a bunch of other TBS out there (EXACT SAME STLYE / LOOK / CONNECTOR) with DIFFERENT pressure ranges -- they will give invalid readings / results
This style was WIDLY used as MAP sensor for all sorts of GM cars/trucks/etc gas or diesel
Pete X/RTS
Jim Sanders (Sandy)
Username: Sandy
Post Number: 54
Posted on Thursday, June 02, 2011 - 3:52 pm:
sorry guys I guess that i will have to wait until i get this scrap heap of mine running( if that ever happens) and then worry about eng controles Thanks any way guys Jim
