Ron Walker (Prevost82) (209.52.245.237)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 01, 2004 - 2:24 pm: | |
Has any one taken off their 22.5 steel rims and put on Alcoa 24.5's. There are a lot of 24.5 Aluim rims in my neck of the woods, but very few 22.5's. What would be the pro's and con's of doing this...I know that a 22.5 has a higher load rating. Ron |
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 01, 2004 - 5:13 pm: | |
I haven't done it, but have discussed this with those who have. Soooss... If you have the additional wheel well clearance AND if your speedometer reads a little slow,... ...then going to a slightly taller tire may help you. The Alcoa wheel has plenty of... ...capacity for a coach application. Also going to a heavy truck sized tire... ...may be $cheaper$ than the expensive 12 inch wide bus tires. Good luck. |
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 01, 2004 - 5:30 pm: | |
I have the room and a electronic speedo that can be recalibated...is there a problem with not get the load rating out of 24.5 tires? Ron |
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 01, 2004 - 6:05 pm: | |
No, and they will probably be less $expensive$ also. |
Larry Baird (Airhog) (159.115.185.216)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 01, 2004 - 8:50 pm: | |
I have 24.5 and no problems on my MC-7 |
RJ Long (Rjlong) (66.229.97.200)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 02, 2004 - 2:32 am: | |
Ron - Don't know several factors with your bus, but I'll use mine as an example to see if this will help answer your question: My 4106 came set up from the factory as follows: 60 mph @ 1650 rpm with tires that turn 495 revs/mile. (Four-speed manual V-drive transmission, 0.808:1 bevel gear ratio, 4.125:1 rear axle, 3.33:1 overall effective ratio, fwiw.) Installing wheel/tire combination that turns LESS than 495 rev/mile will give slightly more top speed, slightly better fuel mileage (moot point), and will have a small effect on hill-climbing ability (you'll have to shift down a little sooner, basically). Installing a wheel/tire combination that turns MORE than 495 rev/mile will have the opposite effect. If you go to several of the major truck tire manufacturer's online catalogs, you'll find load inflation tables. Comparing an 11R24.5 truck tire (which is slightly taller and narrower) to a 12R22.5 "bus" tire, you'll see that there is a difference in the load capacity. This may, or may not, be an issue for you, depending on how heavy your rig is. Which leads me to. . . . . . You MUST weigh your coach, with a reading taken for each axle, to properly set your tire inflation pressures for the best wear, ride, safety & handling of your vehicle. Not to mention finding out if you're actually overloaded!! Again, these load inflation charts are available on most of the truck tire websites. Will the 24.5 Alcoas work on your coach? Technically, yes. But it's your choice. . . HTH, RJ PD4106-2784 Fresno CA |
Ron in SD (24.220.237.100)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 02, 2004 - 8:29 am: | |
Ron, Also remember that you have to replace your wheel studs on the front axle and if you are going to run alco on the inside on the back you will also have to replace the wheel studs on this axle. This is a "hidden" cost on the coversion over to alcos. Ron in SD |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 02, 2004 - 8:34 am: | |
Sorry must not have woken up yet, don't for get the tag axle. You will also need to replace the studs on it. It may be a good time to get the brakes done also because they have to pull the drums off to install the new studs. BTW... You will need two sets of front alcos. One set for the the stear axle and one for the tag axle. |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 02, 2004 - 7:28 pm: | |
Thanks Ron..all good points. It's the weight issue that I was wondering about. I will wait until I can weight it when I have finished the conversion. I have an 82 Prevo so it should come in around the same weight as Larry's MC 7 Ron |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 02, 2004 - 8:29 pm: | |
My MC-7 is 12,700 on the front and 20,350 on the rears. |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 02, 2004 - 9:34 pm: | |
Yea..mine is the same...thanks Larry this will save me a lot of money & time lookin' for 22.5's Ron |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 02, 2004 - 9:37 pm: | |
Hey Larry ...just hit your name and saw your bus...nice...you think you have enough roof air's on bus. I bet when you pass someone walkin down the road they get a chill. LOL Thanks again for the info Ron |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 02, 2004 - 10:12 pm: | |
I don't have a refer, I just leave the food on the table. All that air and no heat, you know I live in Palm Springs. |
