Pick up tube length Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » June 2011 » Pick up tube length « Previous Next »
Username: Chessie4905
Post Number: 2091
Posted From: 71.58.71.157
Posted on Saturday, June 18, 2011 - 2:18 pm:
A poster on the other board asked how far down the pickup tube goes in the tank on a 4905. As I have one sitting down in the shop, I checked it. The tube goes clear to the bottom and would touch, but there is a 3 to 4inch circular depression below the pickup. It is about 3/8 inch deep. You can see this depression from bottom of tank. It also has baffles about every two feet. They are all slotted for movement of the fuel sender arm; regardless if it ever had one. Maybe someone that is registered could forward this to the other site. Thanks
Bob MacIsaac (Wildbob24)
Username: Wildbob24
Post Number: 134
Posted From: 184.37.198.95
Posted on Saturday, June 18, 2011 - 3:40 pm:
John,
Done.
Bob
Post Number: 2092
Posted on Saturday, June 18, 2011 - 8:22 pm:
thanks, Bob
Post Number: 1531
Posted From: 97.224.10.153
Posted on Saturday, June 18, 2011 - 10:57 pm:
JWR...that is amazing from my point of view....that the tube goes so close to the bottom. Wonder how they "avoid" picking up gunk, H2O, etc?
As I recall, mine is considerably higher than 3/8 above the flat...not counting the depression. Been a while since I installed the Webasto pick-up (which I set at about four inches from the bottom), but that is my recollection.
Post Number: 2094
Posted on Sunday, June 19, 2011 - 9:26 pm:
I had the fuel filler off, which left a nice sized rectangular hole. I was able to reach down through the hole with an inspection mirror to check. I would think that normal fuel sloshing will keep the debris moving around, so it can be sucked up so you can change the fuel filters frequently?
Post Number: 1554
Posted From: 76.214.46.131
Posted on Monday, June 20, 2011 - 6:33 am:
A tank sump will collect any in fuel water or tank condensation and suck it into the first filter , that's why it has a drain cock..
This is GOOD as the crud only forms on the tank walls in the presence of water .
Username: Pd41044039
Post Number: 642
Posted From: 184.0.13.120
Posted on Monday, June 20, 2011 - 10:53 am:
I was surprised to find that the tank in a 4104 is built exactly the same way. The tank has a 4" depression maybe 3/8" deep right under the pickup. The pickup goes almost to the bottom of that depression so would get almost every drop. There is a drain plug in the middle of the depression, right under the pickup tube. Remember that these buses were designed to run constantly. In revenue service they didn't sit long enough to grow black gunk. And fuel had WAYYYY more sulphur then which inhibited growth of sludge.
Keep your tank full & treat your fuel if it sits for long. Carry 4 -6 primary & 2 secondary filters and a gallon of fuel to fill them & you will have more than enough for any situation. I had bad sludge & had to change primary filters every 500 miles before removing & cleaning my tank. (Had to make access hand holes & covers behind each baffle to get it clean!)
