Stock MCI restroom questions Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » March 2004 » Stock MCI restroom questions « Previous Next »
Bob Damm (216.134.163.46)
Posted on Friday, March 12, 2004 - 2:53 pm:
Our church is buying an '81 MC-9. I would like to be able to use the sink in the restroom but every commercial bus operator I've talked to said they don't us them and the plumbing seems to be a mystery to them other than the water tank is behind the mirror. Can anyone shed some light on how the plumbing is supposed to work and what I would need to check to make it work??
Thanks,
Bob
ChuckMC9 (Chucks) (68.240.140.141)
Posted on Friday, March 12, 2004 - 7:40 pm:
Mine was covered over, rivited, and all lines had been cut when I got it. Can't imagine why, it doesn't look like rocket science. There's an input to the tank externally on the pass rear, then a line from the tank to the spout. And an output to drain on the ground. One other line but it's too dark to see right now. If you want to know more, just give a ping.
Luke Bonagura (Lukeatuscoach) (12.75.173.49)
Posted on Friday, March 12, 2004 - 9:31 pm:
Hi Bob:
Don't do it!!
A good while back, a bus company had a passenger drink that water and they died.
That was the end of "running water sinks" in coaches!!!!
You can easily provide your fellow church members with a container holding "wet-naps" or some such product to satisfy their needs for sanitation.
I Hope this HELPS!!!
Happy & Safe Bussin' to All!!!
LUKE at US COACH
ChuckMC9 (Chucks) (66.167.165.206)
Posted on Friday, March 12, 2004 - 10:17 pm:
Wow. Never guessed that would've been the reason. There's was a sign on mine that said "non-potable" but that must not have been preventive enough.
BrianMCI96A3 (208.13.135.189)
Posted on Saturday, March 13, 2004 - 12:17 am:
I'm going to connect my wash basin back up it looks to be pretty much all there AND ONLY so I can register the coach as a motorhome, with running water...
Then it will come out with the rest of the bathroom... Non-potable water indeed!
Brian
Phil Dumpster (24.16.243.37)
Posted on Saturday, March 13, 2004 - 5:29 am:
Those tanks don't get cleaned out enough and all kinds of bacteria and microbes live in there.
I don't think the current Greyhound fleet has running water sinks in the restrooms anymore, precisely because of what Luke wrote.
Larry (208.18.102.40)
Posted on Saturday, March 13, 2004 - 8:34 am:
My prevost has two supply lines to the tank, One for water hose to fill the other marked Chemical add, it does smell like a deodorizer and is used in tank as well as hand wash. So who knows what might have been added.
I'm running new water lines to the restroom which is a shower and potty now.
It will be bath and a half.
TWO DOGS (65.177.145.54)
Posted on Thursday, March 18, 2004 - 11:17 am:
my Eagle has a square (?) s/s tank ,about 20 gal...I 'was' thinking of saveing it & the 12 volt water pump to hook-up spray nozzels "IF" the bus overheated on hills....it never has gotten above 182..
Jimmci9 (209.240.205.68)
Posted on Thursday, March 18, 2004 - 3:24 pm:
did the valley get too hot for 'ya 2 dogs??? or just get lonesome for that desolate country nw of amarillo you call home????
TWO DOGS (65.179.200.116)
Posted on Thursday, March 18, 2004 - 5:01 pm:
BOTH....had a good time down there...but...got itchy...wanted to travel...what a neat bus...!!handels great..kinda big for some neighborhood streets..got 9 m.p.g. was happy with that...
Posted on Thursday, March 18, 2004 - 7:33 pm:
so get you a toad....or learn to ride a scooter...
