Flooring Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » July 2011 » Flooring « Previous Next »
Sam Summers (Greyghost)
Username: Greyghost
Post Number: 44
Posted From: 72.35.193.222
Posted on Friday, June 24, 2011 - 9:41 pm:
So I have ripped out all the old carpet and pad looking at the plywood floor. PO had put 1 1/2 insulation foam board down on floor walls and ceiling, no wonder Kevin couldn't hear the engine when test driving it for me.
Anyway I'm torn between carpet, wood floating floors with carpet runners or maybe even both. Wood is easier to keep clean, Carpet has the hidden dirt and the German Shepard doesn't slip all over, any thoughts on this?
Larry & Lynne Dixon (Larry_d)
Username: Larry_d
Post Number: 316
Posted From: 50.39.221.113
Posted on Friday, June 24, 2011 - 10:33 pm:
Good idea Sam if you use laminate be sure to leave room enough on edges for shrink and swell, we didn't and got some swell. Also I used tile and really like it.
Larry
Dave Walker (Chrome_dome)
Username: Chrome_dome
Post Number: 351
Posted From: 75.208.102.253
Posted on Friday, June 24, 2011 - 10:49 pm:
Tile and Lament Pergo The Depot 40.00 a box floats on foam. Run it diagonal and you don't see the seams much. Carpets a pain to put in and you always have to clean. the others just wipe up or sweep up Done.
Chromie
Donald P H (Eagle19952)
Username: Eagle19952
Post Number: 76
Posted From: 75.224.101.189
Posted on Friday, June 24, 2011 - 11:14 pm:
Carpet and self stick/squares of lino tile...tired of it just rip and replace, it's cheap enuough to do that.
Post Number: 1538
Posted From: 97.212.130.252
Posted on Friday, June 24, 2011 - 11:35 pm:
We placed .125 cork sheets (for sound barrier) over existing 1.5 inch Marine Plywood floor..then 1/4" hardwood Parquet...carpet runners( not affixed) from front to back for walkway only.
Dogs have saddle blanket carpets here and there...easy to shake, brush and wash.
ABSOLUTELY no carpet for us...way too much hassle to keep clean with animals, sand etc.etc. BTW, same at home.:-) :-)
FWIW
Username: Larry_d
Post Number: 317
Posted on Saturday, June 25, 2011 - 12:31 am:
I agree with you RC
We had carpet on our five month trip with twenty pugs. When we got home the carpet was out near the next day. The Mississippi mud would not even shampoo out. Used the tile on some show trips and worked great not slick for dogs and wipe and run. We went from the second step to bedroom.
Username: Luvrbus
Post Number: 1160
Posted From: 74.33.60.241
Posted on Saturday, June 25, 2011 - 1:00 pm:
Engineered wood and tile would be my choice
good luck
Username: Ace
Post Number: 1236
Posted From: 173.6.98.47
Posted on Sunday, June 26, 2011 - 10:05 am:
All you guys that are negative with carpet, let me say, its your fault, not the carpet. Its you that chose the wrong carpet for the application. You don't see a thick plush carpet in a doctors waiting room so why would you put it where all the traffic from outside hits it first. Also you don't see plush carpet in a dog kennel so how can you expect carpet to hold up against 20 (TWENTY) dogs regardless of their size.
Bottom line is, carpet will work just as good as hard surface IF you spend the money for the RIGHT product. Something you WON'T find at your bargain or surplus houses. Ours has been in the bus for about 6 or 7 years with a large hair shedding dog and it still likes as good today as day one. And to add, we don't baby it! So before you dis carpet in general, think about what YOU bought and how much it was. It DOES make a difference!
Dan Clishe (Cody)
Username: Cody
Post Number: 119
Posted From: 206.51.120.170
Posted on Sunday, June 26, 2011 - 10:18 am:
I'd like to expand on what clifford said a little, there is a major difference between engineered wood and laminate flooring,, engineered wood floors are layers of actual wood with the grains crossmatched simular to plywood where many kinds of laminate floors are pressed sawdust or particle board with a vinyle covering, if you choose the laminate variety be careful of any areas that might come into contact with water, water isn't friendly to pressed wood and will cause it to swell, engineered flooring is much more tolerant of water. Ace is right about carpeting, as in anything else you get what you pay for, a cheap product is just that, a cheap product. With the small areas in a bus to work with the square footage isn't so great as to cause a major disruptions in the flow of money lol, it'll flow quite nicely as it is so get a good product and enjoy it for many years.
Mike Everard (Meverard)
Username: Meverard
Post Number: 23
Posted From: 98.210.8.135
Posted on Sunday, June 26, 2011 - 11:12 am:
I agree with Ace as far as the quality of the carpet. However, most people have animals, and the places we take our buses are very dusty and dirty. So much for the great outdoors. I like a wood or tile floor because it doesn't trap all of those materials, and it is much easier to clean. I don't have any carpet in my house and that is the way I like it. If someone loves, and maintains, their carpet in the bus, then that is what they are going to suggest. Please remember that no one has the supreme answer on this subject. It is all a matter of what you want.
Good Luck,
Mike
Username: Larry_d
Post Number: 318
Posted on Sunday, June 26, 2011 - 11:57 am:
Yes Ace twenty they are our friends and family. One or all have traveled hundred k miles, due to dog showing. Love em wouldn't have any other way.
By the way the CHEAP carpet was from PO.
Larry
Username: Dallas
Post Number: 611
Posted From: 75.91.199.111
Posted on Sunday, June 26, 2011 - 12:26 pm:
Ahhh, Geez, just use sawdust, blow it out every few days and replace.
Or, use gravel,
How about a bed of hot coals in the cold Northern climes? It'll keep your toes toasty warm, and you won't need socks or slippers!
Think inside the box.... a floor made of Fuller's Earth.... that was the first commercially available Kitty litter, marketed as "Kitty Litter" by Ed Lowe in 1948.
Dan Clishe (Cody)
Username: Cody
Post Number: 122
Posted on Sunday, June 26, 2011 - 12:56 pm:
Sawdust is good and if you enjoy old dances you can do the old soft shoe in your living room and enjoy a higher quality of life.
Username: Jack_fids
Post Number: 814
Posted From: 72.211.145.15
Posted on Monday, June 27, 2011 - 2:23 pm:
Get a Hemp Carpet,
that way you can always smoke it when it's worn out....
sawdust will make you cough too much..!
.....or so I've been told....
Roy Mealer (Road_dawg)
Username: Road_dawg
Post Number: 4
Posted From: 72.178.195.93
Posted on Monday, June 27, 2011 - 5:12 pm:
If you go with the floating floor that requires a foam underlayment, think about using #30 lb. felt instead, does a good job for a lot less $$$
Username: Greyghost
Post Number: 45
Posted on Monday, June 27, 2011 - 5:16 pm:
Oregon is the Capital of Hemp Carpeting, we have just had 91,000 Hemp carpets confiscated about 35 miles from here. The local Sheriff is one of my customers, I wonder if I could get a good deal from him in recycling them.
Just saying that or Peanut shells....
Username: Greyghost
Post Number: 46
Posted on Monday, June 27, 2011 - 5:20 pm:
Roy are you talking Felt as in the material or roofing felt. Thinking might do both, carpet on the sides and a wood walk way down the middle, kitchen & bathroom tile and carpet in the bedroom.
Username: Larry_d
Post Number: 319
Posted on Monday, June 27, 2011 - 8:36 pm:
Sam
If you get to LaGrande come by I could show you the tile I layed down, not pro but works pretty good. Give me a call, number in profile
Larry
Username: Greyghost
Post Number: 47
Posted on Monday, June 27, 2011 - 9:26 pm:
Larry.. Deal
I almost called you up Sunday to take a look but went over rattlesnake to Home Depot to get ideas
Post Number: 353
Posted From: 75.210.71.237
Posted on Monday, June 27, 2011 - 10:11 pm:
"went over rattlesnake"
Must be a Oregon saying, Ummmmmm
Chromie
Username: Larry_d
Post Number: 320
Posted on Tuesday, June 28, 2011 - 12:42 am:
Yes Chromy
Rattlesnake is a grade going into the Grand Rhonde river, deeeeep canyon narrow road and sharp curves. Crossing the river and same going out. Road is Oregon Hwy 3 from Enterprise< OR to Lewiston, ID thru Clarkston, Wn, about 100 total miles. I drove it quite a bit going to the U of Idaho.
Won't be home this weekend, but am home most any other time. Do give me a call. Road is lots of fun to drive fast by a kid with big brass ones and no sense.
Looking forward to meeting you
Larry
Username: Greyghost
Post Number: 48
Posted on Tuesday, June 28, 2011 - 12:44 am:
45 hairpin turns from 4000' to about 700' then back up the otherside, part of the Hells Canyon area
Username: Jack_fids
Post Number: 817
Posted on Tuesday, June 28, 2011 - 1:55 am:
Piece of cake for a 4905 ...
right?
Username: Gusc
Post Number: 1340
Posted From: 173.202.14.54
Posted on Tuesday, June 28, 2011 - 3:38 pm:
We like carpet with runners. Definitely don't like hard slick floors.
Username: Dallas
Post Number: 614
Posted on Tuesday, June 28, 2011 - 4:40 pm:
I use to love playing on Rattlesnake grade.... 110,000 pounds of logs or maybe a D9 on an RGN, Shiny 290, 4X4 two stick, Jakes, and a Rosary... even though I was raised a Mormon... I wanted all the good vibes I could get!
I don't care if it rains or freezes,
'long as I got my plastic Jesus,
Sittin' on the dashboard of my car!
Fooey (Foohorse)
Username: Foohorse
Post Number: 586
Posted From: 166.143.98.191
Posted on Thursday, June 30, 2011 - 1:42 am:
Larry twenty Pugs? GLORIOUS!!! please post or send me a picture.
Post Number: 359
Posted From: 75.247.248.195
Posted on Friday, July 01, 2011 - 1:10 pm:
So Sam what did you decide. Will it be tile , Carpet, Wood, or Rattlesnake skins?
Just wondering about your flooring. You were heading to HD or are you still there.
Chromie
Username: Greyghost
Post Number: 53
Posted From: 69.88.245.34
Posted on Friday, July 01, 2011 - 3:25 pm:
What about carpet on the sides with a wooden walkway in the front area, tile in the kitchen bathroom and carpet in the bedroom. With a Mahogoney wains coat on the walls with a hidden pull out table.
Sam
Post Number: 1455
Posted From: 76.4.118.153
Posted on Friday, July 01, 2011 - 3:39 pm:
what about mirrors on the ceiling too?? I will go along with you so for and I think it will look good.
gomer
Username: Greyghost
Post Number: 55
Posted on Friday, July 01, 2011 - 5:31 pm:
Was looking at ceiling mirrors but brass pole didn't fit in.
Sam
Jim Wilkerson (Wagwar)
Username: Wagwar
Post Number: 161
Posted From: 69.150.233.21
Posted on Friday, July 01, 2011 - 7:17 pm:
I just tore out all of the carpet, cheap laminate and granite tile from stem to stern. Replaced all of it with Armstrong locking laminate. It is so much better than the tile and carpet. I also replaced the tile in the entry way steps with commmercial rubber stair tread and tile. It looks great and I would highly recommend it! The easiest floor and entry to clean that I have ever seen. You can see pics at:
www.mightybus.wordpress.com
I also insulated the back wall of the bedroom above the noise maker with 2" mineral wool insulation. Others advised against it, but it was a big success and has made a HUGE difference in the comfort of the bedroom even on a hot summer day rolling down the road.
Regards,
