Ed Dezz (Sundezz)
Registered Member Username: Sundezz
Post Number: 14 Registered: 1-2005 Posted From: 68.149.43.194
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 17, 2011 - 11:12 am: | |
I have a 72 mci 5b, the front airbag is leaking air . I do have 2 A,bags that came with the bus po never told me if these were the the right ones, these are the good year double convolution A,bags part# 2b12-340 & 2b9-240.Or should i try and buy MCI A,bags? |
Tom Christman (Tchristman)
Post Number: 313 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 17, 2011 - 11:13 am: | |
Go to the Firestone web site and they have a nice table that gives the air bags you need to use. Good Luck, TomC |
Russell Beam (Rcbeam)
Registered Member Username: Rcbeam
Post Number: 65 Registered: 11-2009 Posted From: 74.131.51.228
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 17, 2011 - 4:45 pm: | |
Tom, I did a google search for firestone airbags. Found several sites, but could not find a listing for MCI. Do you have a link we could go to? |
Bob Wies (Ncbob)
Registered Member Username: Ncbob
Post Number: 279 Registered: 2-2006 Posted From: 64.85.179.73
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 17, 2011 - 6:59 pm: | |
You could check the Mohawk catalog to see if the front airbags for and a, b, and c are the same. My guess is that they are. BUT you'll need the hardened bolts and nuts from MCI to make the installation right. It's not an easy task m'friend so be absolutely sure you block the bus so you aren't injured. |
Brian Evans (Bevans6)
Registered Member Username: Bevans6
Post Number: 56 Registered: 5-2009 Posted From: 65.92.54.193
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 17, 2011 - 7:48 pm: | |
I changed mine out with new goodyear bags. I got the bags and the hardware from Luke. It's not a pleasant job, but it ends after a while... You need the new hardware. Brian |
Don Evans (Doninwa)
Post Number: 295 Registered: 1-2007 Posted From: 208.81.157.234
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, July 18, 2011 - 2:52 pm: | |
And Luke will send you all the parts you are apt to need on the first try. |
Post Number: 316 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 20, 2011 - 10:29 am: | |
Try this- http://www.firestoneip.com/literature.aspx Good Luck, TomC |
