Brian Evans (Bevans6)
Registered Member Username: Bevans6
Post Number: 64 Registered: 5-2009 Posted From: 67.71.38.163
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 10, 2011 - 3:25 pm: | |
It's been 8 months since I took the oil cooler off the old engine and I can't remember exactly how it sealed to the block. What I have is the standard single core cooler assembly that has a outlet that reaches up towards the hole in the block. It seems to seal with a fat rubber O-ring that is compressed by a cover with 4 bolts. I wondered if there should be anything else, like a gasket on the block face or some sort of flare attachment or anything? Any goo recommended? thanks, Brian |
Bill Gerrie (Bill_gerrie)
Post Number: 532 Registered: 3-2006 Posted From: 216.198.139.38
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 10, 2011 - 5:14 pm: | |
Brian It is just a rubber "O" ring that seals it to the block. Clean things really well before you reassemble it. I usually put a very thin layer of "ultra grey" silicone just to seal any minor imperfections. If you use silicone don't over do it. Bill |
Post Number: 65 Registered: 5-2009 Posted From: 67.71.38.163
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 10, 2011 - 5:31 pm: | |
Bill, thank you very much. Seemed too simple... Brian |
