4104 flywheel housing size Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » August 2011 » 4104 flywheel housing size « Previous Next »
Username: Pd41044039
Post Number: 662
Posted From: 75.139.102.166
Posted on Thursday, August 18, 2011 - 6:13 pm:
Does anybody know the SAE housing size for the 6-71 in a 4104? I am 800 miles from my bus so I can't look there. I am looking at another engine I want to buy and measured the bolt circle and the housing O.D. both but they come up between SAE 1 and 2. My charts do not show a 1 1/2 housing. Can anybody measure the bolt circle of an engine or trans & let me know?
Username: Joemc7ab
Post Number: 544
Posted From: 66.38.159.33
Posted on Thursday, August 18, 2011 - 10:47 pm:
Jim
I went to the barn and measured the following,6v71 with Spicer transmission attached.This is the one had to grunt last week to torque the flywheel bolts, but it is now mated together, Transmission bellhousing outside measurement is 21 1/2 inches, boltspacing circle is 20 1/2 inches and engine flywheel housing is about a quater inch wider all around the circomference than the transmission housing but somewhat irregular (not perfectly round)
As far as I know this is a SAE #1
Hope this helps Joe.
Username: Luvrbus
Post Number: 1239
Posted From: 184.10.191.147
Posted on Thursday, August 18, 2011 - 11:19 pm:
Twin Disk Torque Converters used a weird size bellhousing on the DD,are you sure it is not a step down adapter on a SAE 1
good luck
Post Number: 663
Posted on Friday, August 19, 2011 - 8:18 am:
I don't think so, it was in a TDH4512 and had an Allison VH on it.
This F/W housing bolt circle is 19" and the O.D. of the engine housing casting is 20". That's midway between SAE 1 & 2 sort of 1 1/2.
I'll be bummed if I have to change the gear/flywheel housing. I'm buying the engine for the external 4104/stick specific parts to convert another 6-71 I have.
Troy Burcham (Badlybentmc7)
Username: Badlybentmc7
Post Number: 5
Posted From: 184.5.152.209
Posted on Thursday, August 25, 2011 - 1:37 pm:
I have a flywheel housing an a motor sitting in my barn the housing is like new.If you are not in a hurry i can get over there this saterday and check it for you.if you need the housing it can be yourS. you can call me on my cell 434 962 7748 and let me know. thanks Troy b.
