79 Newell, 36 ft Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » August 2011 » 79 Newell, 36 ft « Previous Next »
Peter Kent (Henisland)
Username: Henisland
Post Number: 8
Posted From: 70.168.202.92
Posted on Saturday, August 20, 2011 - 11:29 am:
I am changing out original 555 cummins to 6v92 silver with 747HT 4 spd. Need to change out rear pumpkin to 3.21 or 3.42 It is a 14 bolt Rockwell. Anyone know where I can find this gearset/pumpkin. Bus is in Missouri, I am in Florida. Thanks Pete
Username: Luvrbus
Post Number: 1240
Posted From: 184.10.191.147
Posted on Saturday, August 20, 2011 - 11:38 am:
You can get the gear set from Pro Gear in Orlando FL or Global Gear in Houston Tx but I think it will be a 3:36
good luck
(Message edited by luvrbus on August 20, 2011)
Post Number: 1580
Posted From: 76.214.45.168
Posted on Sunday, August 21, 2011 - 7:52 am:
Replacing a 4 stroke with a 2 stroke usually requires more rpm at cruise.
What will be your target RPM at 50, 60,70mph?
FF
Username: Luvrbus
Post Number: 1241
Posted on Sunday, August 21, 2011 - 10:14 am:
He shouldn't have a problem the 6v92 loves a 3:36 and the triple nickle Cummins was a 2400 to 3300 rpm engine the gutless wonder of the world he probably has a gear in the 4:xx or lower for the 555 to low for a 6V92
good luck
(Message edited by luvrbus on August 21, 2011)
Tom Christman (Tchristman)
Username: Tchristman
Post Number: 327
Posted From: 66.218.33.156
Posted on Monday, August 22, 2011 - 12:13 am:
Instead of changing out the rear end, you could exchange the HT740 for a HD4060 or B500 that has a .74 and .64 rear end ratio. Would work well with the 4.xx ratio you have now. Good Luck, TomC
