Resurrectring the Drivers A/C system Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » August 2011 » Resurrectring the Drivers A/C system « Previous Next »
Jim Wilkerson (Wagwar)
Username: Wagwar
Post Number: 172
Posted From: 69.149.222.17
Posted on Tuesday, August 23, 2011 - 12:59 pm:
I am in the process of resurrecting the drivers a/c evaporator in my MC 9. However, I ran into a snag - the two defrostor motors under tha dash that are used for the drivers heat/defrost/ac are bad. Yes, MCI will selll them to me for $355 each! I was hoping for a less expensive route. I took them to an repair shop that is very experienced and they cannot find parts or a 24volt replacement.
Does anyone have a good pair of these motors? or at least, a pair with good armatures. My shop can fix any other problems but the armatures on mine are shot.
Regards!
Post Number: 1523
Posted From: 76.4.118.199
Posted on Tuesday, August 23, 2011 - 6:20 pm:
Call Luje at US Coach
Gomer
Mark Renner (Boomer)
Username: Boomer
Post Number: 246
Posted From: 75.220.41.53
Posted on Tuesday, August 23, 2011 - 8:37 pm:
Kirk's Automotive will have them. www.kirksauto.com
Could also try Mohawk. Both outfits are coach unit suppliers.
Brian Evans (Bevans6)
Username: Bevans6
Post Number: 72
Posted From: 65.92.51.90
Posted on Wednesday, August 24, 2011 - 9:40 am:
I did the typical replace the brushes, clean the commutator, lube the bearings rebuild on my motors and they came in fine. My local electric motor rebuild place was able to supply the brushes.
Brian
Username: Chessie4905
Post Number: 2137
Posted From: 71.58.71.157
Posted on Wednesday, August 24, 2011 - 9:55 am:
You sure that the armatures don't just need cutting and new brushes? Find an electric motor rebuilder or older starter/ alternator service shop. Majority of AC shops don't do this kind of work.
