thomas flocks (Taflocks)
Registered Member Username: Taflocks
Post Number: 486 Registered: 9-2009 Posted From: 67.253.124.108
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 25, 2011 - 3:29 pm: | |
i need someone to trace on a piece of paper the hoop of the latch that holds the a/c cage door closed. i lost both of mine when i hit a historical marker and dragged it 50 feet down the road. thanks in advance tom |
Post Number: 900 Registered: 1-2009 Posted From: 72.211.145.15
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 25, 2011 - 5:12 pm: | |
Your local Truck Supply retailer or TruckStop will have rubber Hood-Latches with retainers for less than $10 , buy a pair & replace the damaged ones, it is a simple as replacing a signal light. NOW.. you posted this previously: 4106 ROT Posted on Tuesday, August 16, 2011 - 5:16 pm: I will have to take a picture to post here. Have you found a solution yet ? The photo I posted for you shows the area adjacent to the A/C Cage... the ribs you see run under the fuel tank, do they resemble yours? |
Post Number: 487 Registered: 9-2009 Posted From: 67.253.124.108
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 25, 2011 - 5:42 pm: | |
yes they do, but luke says he has none. the hinges i have are not rubber type and i like the ones that are there but i just need the hoops that go over the latch. we can bend a rod to fit if we had a pattern to go by. |
Post Number: 902 Registered: 1-2009 Posted From: 72.211.145.15
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 25, 2011 - 6:14 pm: | |
Mine are missing too I'm sorry to report. As for your "under-tank bracing" all you need is 12 ga. double wall tubing... Slip a round piece into a proper length of 3/4 in.or 1-in. Square tube, weld the ends together, drill & bolt them into place & rust-proof them before you install them. fwiw |
Post Number: 488 Registered: 9-2009 Posted From: 67.253.124.108
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 25, 2011 - 6:26 pm: | |
i was thinking just flatten the ends and drill a hole at the proper length,much easier than paying someone to weld them. |
Larry D Baker (Lbaker4106)
Registered Member Username: Lbaker4106
Post Number: 105 Registered: 5-2005 Posted From: 98.135.37.131
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 25, 2011 - 6:45 pm: | |
I purchased some parts from Bus Service Inc., 111 Hwy 52 Bypass W., Layfette, Tn., 37083 Phone number was 615-666-8500 Haven't talked to them since 2005 but may be a start. If nothing else I could measure mine. |
Post Number: 489 Registered: 9-2009 Posted From: 67.253.124.108
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 25, 2011 - 7:14 pm: | |
i will call in the morning, thanks! |
Post Number: 1259 Registered: 8-2006 Posted From: 184.10.191.147
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 25, 2011 - 7:52 pm: | |
FWIW John has moved Bus Service to Sharon Springs KS 785-891-3557 you can buy online also he has a web site |
Darrell Black, DVM (Darrelldvm)
Registered Member Username: Darrelldvm
Post Number: 65 Registered: 6-2005 Posted From: 72.4.181.208
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 26, 2011 - 1:51 am: | |
Tom, I think the latch for the battery door and the elect door have the same latch as the AC door. Darrell |
Post Number: 490 Registered: 9-2009 Posted From: 67.253.124.108
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 26, 2011 - 6:52 am: | |
not on mine i have no latch .lust duct tape on the battery door.i have the rubbers for that but just need to get around to doing it. |
