Finally down to the king pins. Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » May 2004 » Finally down to the king pins. « Previous Next »
John Rigby (24.174.238.253)
Posted on Saturday, May 08, 2004 - 6:06 pm:
I have got everything off the front end of the 04, I cant imagine life without a 4 to 1 tourque multipler(I rented one, now im going to buy one ).
The bolt is undone, the split pin underneath is off,HOW DO YOU GET THE BLOO-- King pins out. I have beat on them no go?
Thank You
John
Jimmci9 (209.240.205.68)
Posted on Saturday, May 08, 2004 - 7:05 pm:
for sale:::; 4x1 torque multiplier.... see me when you get to traders village....jim
Geoff (Geoff) (66.238.120.68)
Posted on Saturday, May 08, 2004 - 9:35 pm:
I'm not sure what your setup looks like, but you might try putting a bottle jack under the king pin and beating the axle down with a small sledge hammer so the pin will pop out. You may also need to heat the housing up with a rose bud torch.
Posted on Sunday, May 09, 2004 - 7:20 am:
Thank You guys. Somone mentioned brake fluid as one of the best penetrents. I will try some today.
John
Nick Morris (Nick3751) (69.34.105.21)
Posted on Sunday, May 09, 2004 - 8:03 am:
Never done King pins John but when doing ball joints all the beating in the world on the top of them won't move 'em. TAP once or twice on the SIDE and they fall out!!!!!
Learned that from an old mechanic after trying to beat a set out for two days.
BrianMCI96A3 (65.41.248.184)
Posted on Sunday, May 09, 2004 - 9:45 am:
Well Nick, besides having had my fair share of replacing king pins and ball joints, I can safely say that relatively few times in my career have I been lucky enough to have something come apart with a couple of taps to the side.
Worn king pins can almost slide right out... or need to be pressed out; depends a great deal on their condition.
A little heat (or a lot) around the outside, a piece of 1" shaft or something like it, to drive the king pin out, and a sledgehammer to hit it, ought to do the trick.
You need to make certain the axle is supported solidly.
Brian
Posted on Sunday, May 09, 2004 - 6:11 pm:
Jim
Please save the torque multiflter till we get there . my dates were wrong we will be at traders 5/28/29 and 30th.If I can get these king pins out.
John
Posted on Monday, May 10, 2004 - 9:02 pm:
Jim,Geoff,Nick,Brian,Leroy, Luke,Bill,Mike and the boys,Thank you for all your help, THE FRONT KINGPINS ARE OUT.
I must say I have a great respect for Bill, Lukes shop foreman, him and his guys do this every day.
Thanks again, Now its just getting everything back right.
John
Roderick W. Chandler (172.159.227.170)
Posted on Wednesday, May 12, 2004 - 8:24 pm:
Okay. Glad your were able to get the kingpins out. Would you like to share how you did it?
John Rigbyj (24.174.238.253)
Posted on Saturday, May 15, 2004 - 7:20 pm:
The rear break,shoes,drums,bags,bearings last year was a breeze compaired to these king pins.
I thought it was hard geting to them and getting them out. Boy its quite a task puting them back together, line up shims etc.
John
