Lights dimming Cont.. Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » September 2011 » Lights dimming Cont.. « Previous Next »
Austin Scott Davis (Zimtok)
Username: Zimtok
Post Number: 473
Posted From: 173.166.209.1
Posted on Friday, September 02, 2011 - 11:30 am:
Remember when I had the problem of my lights dimming when I made a right had turn????
Well I think I found the problem finally.
The starter solenoid has a spring that keeps the contact from touching the terminals unless the solenoid it activated to start the engine.
WElL...
The spring had failed and as I turned right the the contact disc would run the started motor. Because it was running without the solenoid engaging there was no damage to the Bendix gear or the flywheel.
I will be sourcing a new solenoid but for now I just inserted a new spring and cleaned and turned the one terminal contact around for a better connection.
This is what it looked like when opened.
Notice the broken spring on the end of the contact disc...
solenoid contacts as found
This is it cleaned up and new spring installed...
cleaned up
Username: Dallas
Post Number: 703
Posted From: 98.20.48.154
Posted on Friday, September 02, 2011 - 11:45 am:
Well, that'll make ya think, "Darnit".
I rebuilt the plate and the contacts on a MT50 solenoid once with a potato and a piece of soft copper tubing.
Now..... that'll give you pause for thought. Anyone know how it was done? Jack, you don't count!
Hint.... it took a month.
Username: Zimtok
Post Number: 474
Posted on Friday, September 02, 2011 - 1:55 pm:
I found this replacement starter solenoid online for $43+ standard shipping brought it up to $51
http://www.smithcoelectric.com/servlet/the-209/1115606-1119879-1969198-1115556/Detail
NAPA locally had 2 in stock but at the price of $151 I opted to order the one online.
Username: Gusc
Post Number: 1365
Posted From: 173.202.17.148
Posted on Friday, September 02, 2011 - 3:44 pm:
Thanks Zim,
That is a very good source for us GM owners.
Username: Chessie4905
Post Number: 2147
Posted From: 71.58.71.157
Posted on Friday, September 02, 2011 - 10:57 pm:
you worked the tubing into a replacement disc and lived on the potato for a month.
Username: Jack_fids
Post Number: 922
Posted From: 72.211.145.15
Votes: 2 (Vote!)
Posted on Saturday, September 03, 2011 - 12:49 pm:
What a valiant attempt at comedy..!
...and here I thought you were all hostile over subjectively funny retorts that added no value to a subject.
I guess it just goes to show how wrong a guy can be ...eh?
A month Dal ?
That just happens to be the length of time it takes a Spud to ferment..!
(Message edited by Jack_fids on September 03, 2011)
Username: Dallas
Post Number: 704
Posted on Saturday, September 03, 2011 - 1:05 pm:
Well, I'll give ya'll another hint.
Baghdad battery
Post Number: 2148
Posted on Saturday, September 03, 2011 - 5:49 pm:
you re-plated bolt end and disc, using the copper tubing to supply material.
Username: Dallas
Post Number: 705
Posted on Saturday, September 03, 2011 - 8:44 pm:
Bingo! Chessie takes the brass ring!
For the record, it wasn't really needed, but I just wanted to see if we could do it.
Post Number: 2149
Posted on Saturday, September 03, 2011 - 11:02 pm:
funny retorts wasn't the problem; rambling rhymes of many lines that didn't seem to in any way to be relevant.BTW, you can hammer a piece of copper tubing into a disc with enough time.
Username: Jack_fids
Post Number: 925
Votes: 2 (Vote!)
Posted on Saturday, September 03, 2011 - 11:15 pm:
