Allison Transmission Oil Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » September 2011 » Allison Transmission Oil « Previous Next »
Moe Hollow (Moehollow)
Username: Moehollow
Post Number: 104
Posted From: 71.102.18.102
Posted on Wednesday, September 07, 2011 - 3:56 pm:
Time to change oil in my allison 644. It used to be that we looked for a C-4/ dex2 or 3. Now Allison wants everyone to buy Transynd, which is rather expensive. I have read where the military uses a 15w40, C-4 oil like Rotella T3. I have also heard of using 30w drive train oil, or hydraulic/transmission oil. I was wondering what others here are using. Thanks
Laryn Christley (Barn_owl)
Username: Barn_owl
Post Number: 720
Posted From: 108.15.206.248
Posted on Wednesday, September 07, 2011 - 10:10 pm:
My v730 gets Dex3.
Jim and Myrna Lawrence (Daffycanuck)
Username: Daffycanuck
Post Number: 78
Posted From: 142.165.85.203
Posted on Thursday, September 08, 2011 - 12:12 am:
My 650 gets DexIII
Ed Hackenbruch (Ed_hackenbruch)
Username: Ed_hackenbruch
Post Number: 16
Posted From: 166.250.0.233
Posted on Thursday, September 08, 2011 - 12:40 am:
i had them change my 644 over to Transynd.
Username: Luvrbus
Post Number: 1264
Posted From: 184.10.191.147
Posted on Thursday, September 08, 2011 - 12:48 am:
I always used CAT TDTO 10w oil in the 740 good enough for a $35,000 Cat transmission was ok for me never had a problem with one using it over the years.
Cat also sells a synthetic blend that is good oil.
The Transynd is a must for the World Transmissions but I wouldn't spend that type money for oil in a 644 it takes 2 changes
good luck
Dave Walker (Chrome_dome)
Username: Chrome_dome
Post Number: 386
Posted From: 74.41.14.235
Posted on Thursday, September 08, 2011 - 1:15 am:
My mt 654 uses good old regular ATF Red
Dave
Username: Moehollow
Post Number: 105
Posted on Thursday, September 08, 2011 - 2:48 am:
Thanks- It seems some are happy with regular Dex III. I do like the idea of the TDTO except I just looked up the temp range for the 10 and 30 wts, and they are rather low. The multigrade (TDTO-TMS)is rated to about 110 degrees though. Any reason that wouldn't work?
Username: Luvrbus
Post Number: 1266
Posted on Thursday, September 08, 2011 - 9:33 am:
Moe are you sure that is not a 110C not degrees
good luck
Username: Moehollow
Post Number: 106
Posted on Thursday, September 08, 2011 - 11:14 am:
Yeah, Although the chart was in C, I did a rough switch to F. Unless I am missing something, it looks like the F numbers are -4 to 50 for 10w, 32 to 95 for 30w, and -4 to 109.4 for TMS. Here's the link I got
http://docs.google.com/viewer?a=v&q=cache:9jrsP0K1C9UJ:www.cat.com/cda/files/1386248/7/PEH P8035-02.pdf+caterpillar+tdto+oil+temperature+range&hl=en&gl=us&pid=bl&srcid=ADGEESjyNjLmV hNU5-GsBAN2VQTal-Bmt0bFhvVe7q1EKSgcvwXXAMlyw1Itr-29x4S67e0SufOSsqTrWs2_xK7ykAtf94Gq_yBfFvz jCLNVxGkOOC4Nu6XvwJ2Pv2UJvvGltDCvuzdJ&sig=AHIEtbSt8NTn77mwP8pgqev0hcKkFqV6Pg
Username: Pd41044039
Post Number: 673
Posted From: 184.0.13.120
Posted on Thursday, September 08, 2011 - 11:53 am:
Moe, I can't access your link, but those temp ranges look like they are meant for ambient air temps, not oil temps.
Username: Moehollow
Post Number: 107
Posted on Thursday, September 08, 2011 - 11:56 am:
Sorry if I was not clear. They are ambient air temps as you say, but isn't that critical too?
Username: Dreamscape
Post Number: 745
Posted From: 74.2.251.162
Posted on Friday, September 09, 2011 - 5:19 am:
I'm getting ready to install a 740 in our Eagle. What is the current recommendation?
Post Number: 17
Posted From: 166.250.1.131
Posted on Friday, September 09, 2011 - 8:49 am:
The Detroit shop did a complete flush and filter change on mine so i did not have to do a second change. The initial cost to change over is more but the savings comes from the increased service interval. Cheaper in the long run.
Username: Luvrbus
Post Number: 1267
Posted on Friday, September 09, 2011 - 8:59 am:
Paul, the 740 shifts the best with 15/40 C-4,I have always used Cat Fluid it is the same as Delo 100- 10W those transmissions run a million miles on DEX or other fluids all the hype about Transynd I never bought into for 740 after all they get about 300,000 from the world transmission using Transynd wonder what they would not using it lol.7 or 8 gals at 10 bucks a qt naw not this one
