Post Number: 944 Registered: 1-2009 Posted From: 72.211.145.15
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 19, 2011 - 2:39 pm: | |
http://www.theleafchronicle.com/article/20110919/NEWS01/110919002/Five-bodies-Clarksville- Speedway-Identified?odyssey=nav|head One small lapse in thinking = 5 dead in their sleep. |
Post Number: 1370 Registered: 11-2005 Posted From: 173.202.30.60
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 19, 2011 - 3:57 pm: | |
This is a no brainer, I never go to sleep with the genset running-period! |
Post Number: 694 Registered: 2-2001 Posted From: 184.0.13.120
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 19, 2011 - 7:56 pm: | |
Well, with the opposing view, we do sleep with the genset running but have multiple functioning carbon monoxide detectors. If we are in a place where there are other campers or trucks alongside, (OR right next to a building or other obstruction) we use the removeable stack that goes about a foot above the roof of the bus. Multiple carbon monoxide screamers are mandatory for us. We use wood stoves & kerosene heaters at home as well and have never had the monoxide detectors show ANY registerable numbers (yes they work and do indicate when tested). |
Post Number: 560 Registered: 6-2004 Posted From: 66.38.159.33
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 20, 2011 - 12:58 am: | |
The typical CO monitor that you buy at the big box store may not do as good a job as you might think. We have one plugged in a wall outlet and it allways registers zero. I also have an expensive portable type that I use when doing inspections, and it showed 5ppm last winter inside the house for a while untill I found the problem. Another area for concern is windows located near or above operating appliances like hotwater heaters or furnaces, and we wont even begin to talk about non vented stuff. Joe. |
Post Number: 561 Registered: 6-2004 Posted From: 66.38.159.33
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 20, 2011 - 1:02 am: | |
Jim Just because it has a test button does not always prove that the unit is functional and trustworthy. Joe. |
Post Number: 1374 Registered: 11-2005 Posted From: 173.202.3.164
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 20, 2011 - 3:09 pm: | |
Ditto to my first post plus we don't park next to anyone using one. |
