Changing thermostat for winter Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » September 2011 » Changing thermostat for winter « Previous Next »
Darrell Black, DVM (Darrelldvm)
Username: Darrelldvm
Post Number: 67
Posted From: 72.4.181.208
Posted on Monday, September 19, 2011 - 11:10 pm:
I have 180 degree thermostats, thinking of increasing to 190 degree for winter. Have you done this?
Second question: Are 4106 windshield wiper arms available (new)
Username: Pvcces
Post Number: 1386
Posted From: 141.0.8.158
Posted on Tuesday, September 20, 2011 - 2:24 am:
The usual reason for installing different thermostats is that an engine runs warmer of colder than desired.
In most cases, money is much better spent on fixing whatever is causing the problem; this is rarely the thermostat.
For what it is worth.
Suncatcher
Ketchikan, Alaska
Brian Evans (Bevans6)
Username: Bevans6
Post Number: 76
Posted From: 67.71.37.121
Posted on Tuesday, September 20, 2011 - 8:54 am:
I have to ask what will 190 degrees do for you that 180 degrees won't? If it's just heating the interior of the bus while travelling, 180 degrees is ample, you won't notice a difference. I wouldn't change unless you suspect your current thermostats are broken, and even then I would put the 180's back in. In fact, I just checked my manual and stock thermostats on my bus are 170 degrees.
Brian
Username: Pd41044039
Post Number: 695
Posted From: 184.0.13.120
Posted on Tuesday, September 20, 2011 - 9:31 am:
If you are going to be driving around someplace like Minnesota this winter you would be ahead to repair or replace the radiator shutter system if your bus had them. Also, your bus (4106) should have a thermostatically controlled fan clutch (taurus).
If the coolant is cold, the fan should be loafing.
In really cold weather, big rig truckers install the fabric radiator covers but if you put anything in front of the radiator be sure it is balanced as to the area covered. If you cover, say the bottom but not the top the fan flexes when it rotates through lower & higher pressure areas. This can cause the fan or attachments to fail. (It normally takes out the radiator when it does.)
Username: Gusc
Post Number: 1372
Posted From: 173.202.3.164
Posted on Tuesday, September 20, 2011 - 3:06 pm:
Trucker radiator covers often have different sized holes in the center that are have snaps to adjustable the size.
A hole in a piece of cardboard will do the same if you leave a couple of flaps in place.
Post Number: 2126
Posted From: 174.89.176.17
Posted on Tuesday, September 20, 2011 - 10:29 pm:
I would caution putting anything in front of a rear engined coach's radiator.
The radiator isn't out in the wind like a truck.
I have purposely run alongside 2-stroke coaches in winter weather to observe the shutters. I have yet to see the shutters close on the open highway. They will close fairly quickly as the load is removed as the coach slows and idles around into a parking space at a service centre.
If you are going to run in the cold, I would encourage returning the shutters to operating condition.
I am partial to ignoring/removing/rendering inoperative the fan damper doors in an MCI, as they were usually the first problem towards overheating in fleet service.
The shutters do a good job of cutting the air flow for a busnut.
Username: Gusc
Post Number: 1378
Posted From: 75.121.202.216
Posted on Tuesday, September 27, 2011 - 7:55 pm:
Shutters are great if you have them, I have one with and one without.
Austin Scott Davis (Zimtok)
Username: Zimtok
Post Number: 479
Posted From: 173.166.209.1
Posted on Wednesday, September 28, 2011 - 10:14 am:
I fixed the shutters on my 4104 and I'm very happy with them.
I get better heat in the cold, and the engine runs better when up to temperature. (especially when it is sucking in dense cold air)
Username: Gusc
Post Number: 1381
Posted From: 173.202.20.114
Posted on Wednesday, September 28, 2011 - 6:57 pm:
Wish my 4107 had shutters but not sure they ever had any.
