Post Number: 1587 Registered: 7-2006 Posted From: 97.212.233.45
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 22, 2011 - 9:06 pm: | |
.....I posted a few days ago. Question: how does HEAT affect batteries? Thanx, much! RCB |
les marston (Les_marston)
Post Number: 368 Registered: 1-2010 Posted From: 68.151.225.213
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 22, 2011 - 9:23 pm: | |
A battery that is to cold will loose efficiency. Everyone knows that. Heat can also adversely effect a battery as heat can be represented as resistance so it only makes sense that an extremely hot battery will not preform as well as one at a normal ambient temperature. I would assume that you would need to add water much more often and that the plates in the battery would fail a lot sooner. I am not sure if that helps but I would suggest that if you have a battery in an extreme heat condition that moving it or providing some form of cooling, possibly more venting would be a good idea. Remember that batteries live in the engine compartments of a lot of vehicles where there is a lot of heat so you would have to compare that to the situation that your battery is in |
Post Number: 1278 Registered: 8-2006 Posted From: 184.10.191.147
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 22, 2011 - 10:17 pm: | |
The AZ heat will destroy a battery 2 years here is about the max life and makes no difference in price or the construction process I got 3 years from the Lifeline AGM's here if I was lucky good luck |
Post Number: 952 Registered: 1-2009 Posted From: 72.211.145.15
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 23, 2011 - 2:40 pm: | |
I'll support that position...! In Mini-Soda a Die-Hard would last me 4-5 years Arizona....? Try 2-3 and that is with regular maintenance. |
Post Number: 1588 Registered: 7-2006 Posted From: 70.218.92.251
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 23, 2011 - 9:14 pm: | |
Well, folks....not talking about climate; rather heat caused by the genset, or other things in the immediate proximity, such as within an enclosure, tight premises, etc. Just trying to get a handle on why a new battery is going "south" so fast. That battery has been "off grid" for a couple of days and is holding the charge fine. (12.86+) Must be something that is causing it to go down when "under load"....???? Something tells me that it could not be good...or? Thanx! RCB |
Dave Walker (Chrome_dome)
Post Number: 393 Registered: 3-2010 Posted From: 75.210.89.77
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 23, 2011 - 9:22 pm: | |
Mine is in another compartment next to the generator. Heat is heat and will shorten the life. Dave |
Post Number: 565 Registered: 6-2004 Posted From: 66.38.159.33
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 23, 2011 - 10:01 pm: | |
Chuck I cannot give you a treatise that x percentage shorter life at such and such a temperature but trying to keep the temperature down is something that should be practiced. This is the reason why in some installations the battery compartment has a thermostatically controlled fan that kicks in at the preset high temp setting. We have this in our new bus. Also some charging systems have a temperature sensor mounted on the battery with a feedback loop to the controler/charger to prevent overheating of the batteries. Now if you are happen to live in an oven for the summer, with temps well in excess of a hundred then I guess there is not a whole lot that can be done other than stcking them in a freezer. Then you replacate the conditions that we experience in mid winter. You only freeze them once and it is replacement time. Joe. |
