82 eagle steering wheel Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » September 2011 » 82 eagle steering wheel « Previous Next »
Jason Simons (Bigblock01)
Username: Bigblock01
Post Number: 43
Posted From: 75.203.103.163
Posted on Monday, September 26, 2011 - 12:23 pm:
I need to change the steering wheel on our Eagle does anyone know what would interchange with it in truck line kw, pete, maybe.
Username: Luvrbus
Post Number: 1279
Posted From: 184.12.160.98
Posted on Monday, September 26, 2011 - 12:40 pm:
Any 1 in x 36 spline will work Vip has the wheels FWIW you don't have to change the hub the wheel has 3 bolts to remove it from the hub
A Freight Liner wheel will work I don't know about others
good luck
Post Number: 44
Posted on Monday, September 26, 2011 - 1:45 pm:
Thanks I would not change but I'm a little oversized to fit comfortably. We use it for our group right now my uncle drives but I need to be able to relieve some.
Username: Dallas
Post Number: 720
Posted From: 75.91.206.80
Posted on Monday, September 26, 2011 - 2:26 pm:
So what happens if the Power Steering quits from a major blow out of the lines? With the 22"? wheel you can get it into any place you need to, with an 18" wheel you'll fight that sucker even at 30 mph to make it go where you want it to.
How about looking at resetting the seat location if you have a problem with the belly spacing?
Setting the mounts 1 1/2" back can make a big change on the Done-Lap.
Plus, it won't cost a thing except some exercise and some time.
Post Number: 45
Posted From: 174.254.128.213
Posted on Monday, September 26, 2011 - 5:17 pm:
I'm going to try removing the wall from behind the seat and move it some but sets on lower level on eagle. Trying dieting just to slow a response time.
Username: Dallas
Post Number: 722
Posted on Monday, September 26, 2011 - 6:50 pm:
Jason, for goodness sakes, don't start dieting! What would you live on when the world comes to an end? Besides, us fat people have to stick together!
I'm not sure what your seat mount looks like, but at one time I cut off the rear of the mounting flange on a Bostrom seat and that allowed it to move back enough for my driver to be comfortable.
Post Number: 46
Posted From: 174.252.133.206
Posted on Monday, September 26, 2011 - 6:59 pm:
It's a bostrum air ride I think once oe hand rail is removed it will go probably another two inchs
