Dan (Cintrepd)
Registered Member Username: Cintrepd
Post Number: 21 Registered: 8-2008 Posted From: 74.198.164.193
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 27, 2011 - 3:26 pm: | |
Hi just installed an allison auto tranny in my mc9 6v92 and it wont start or even turn over despite power to the starter? Ps did have a manual teanny before this unstall Any ideas? Tks! |
Mark Morgan (Stormcloud)
Registered Member Username: Stormcloud
Post Number: 16 Registered: 9-2008 Posted From: 216.36.185.106
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 27, 2011 - 4:01 pm: | |
Is it 'in gear'? Power to the starter meaning power is through the solenoid to the starter motor and it doesn't spin? Can you hear the solenoid engage? |
Dan (Cintrepd)
Post Number: 22 Registered: 8-2008 Posted From: 74.198.164.193
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 27, 2011 - 4:15 pm: | |
It is not in gear. It meanz electrical power to the starter but it wont turn over? |
Jack Campbell (Blue_goose)
Post Number: 152 Registered: 5-2007 Posted From: 71.101.61.100
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 27, 2011 - 4:48 pm: | |
There is a pin that I think goes into the modulator. If you leave it out the transmission will be locked. Jack |
thomas flocks (Taflocks)
Registered Member Username: Taflocks
Post Number: 513 Registered: 9-2009 Posted From: 67.253.124.108
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 27, 2011 - 5:06 pm: | |
neutral safety switch? |
George M. Todd (George_todd)
Post Number: 1291 Registered: 8-2006 Posted From: 99.29.76.231
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 27, 2011 - 11:29 pm: | |
Dan, By electrical "power to the starter," do you mean the main cable, or the start wire to the solenoid coil? It will take both to start. Is the rear start/run switch in the run position? Do you hear any noise when you push the start switch, as in a click from a relay, or a louder clunk as the solenoid engages the starter, but it doesn't turn? Was the Amphenol plug reconnected after the engine and trans were reinstalled? Grounds? Check all of this out please, and if it still won't start, post back. G |
Dan (Cintrepd)
Post Number: 23 Registered: 8-2008 Posted From: 74.198.164.206
Rating: Votes: 2 (Vote!) | Posted on Wednesday, September 28, 2011 - 6:48 am: | |
Bad ground - thanks for all the replies! |
