Article on my Military/NATO 8v-71T pr... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » October 2011 » Article on my Military/NATO 8v-71T project « Previous Next »
Brian Evans (Bevans6)
Username: Bevans6
Post Number: 82
Posted From: 67.71.36.165
Votes: 2 (Vote!)
Posted on Saturday, October 08, 2011 - 4:58 pm:
Converting a Military/NATO 8V-71T for use in a Bus Re-power
Brian Evans October 8, 2011
When I was looking at what to do to fix my worn out 8V-71 in my 1980 MCI MC-5C, one big question I had was could I use one of those surplus military 8V71T’s that seem to come and go on the market. I got a lot of advice, mostly don’t do it, funny things go on with those engines. Well, I bought a NOS surplus engine that I thought at the time was an industrial engine for a pump application, and installed it in my bus. Late in the game I found out that the engine number I have, 7083-7395, is indeed a NATO military engine used in that or very similar specification, in self propelled howitzers, troop carriers, tenders, and recovery vehicles among other things. Having done the job and completed it just recently, I thought I would document the differences and challenges that I had to overcome to get this thing into the bus and running.
This article focuses on the engine and the differences that had to be overcome to make it a bus engine.
What is a Military/NATO Engine?
Mine is a 8V-71 turbocharged engine with these specifications, from the manual for an M-110 self Propelled Howitzer:
ENGINE 8V-71T 7083-7395
Manufacturer Detroit Diesel Engine Division, GMC V-8, compression-ignition, liquid cooled
Type Turbocharged, two-cycle diesel
Model (7083-7398) or (7083-7395) 8V71T
Weight, Dry (as installed) 2,442 lb (1,107.7 kg)
Number of Cylinders 8
Displacement 568 cu in. (9,308 cm3)
Bore 4.25 in. (10.8 cm)
Stroke 5.0 in (12.7 cm)
Compression Ratio 17:1
N-80 Injectors
DW-LS governor
Horsepower, Gross Brake (at 2,300 rpm) 405 (302 kW)
Horsepower, Net Brake 345 (257 kW)
Maximum rpm. No Load (governed) 2,450 rpm
Idle Speed 650-700 rpm
On the face of it, an ideal candidate for a bus transplant. Mine was a factory rebuild that had been sold as surplus and stored in various sheds and barns, well sealed. It was perfect inside, some storage rust on the outside. There are quite a few differences between it and an MCI bus engine, all in the ancillaries that bolt on to the basic engine. How hard could it be? About 200 or 300 hours and $6200 hard… over and above the cost of the engine.
I used normal hand tools, a three foot breaker bar, my 700 ft-lb torque wrench and a 250 ft lb torque wrench, and various pullers. Nothing outrageous. I built the engine dolly to remove and roll the engine around on, an engine stand system that consisted of four legs that bolt to the side of the engine block, and an A-frame crane that I built to take a 4,000 lb chain hoist. I used Permatex Aviation #3 gasket sealer, a brush-on liquid sealer, on all gaskets. I didn’t use any silicone anywhere. I bought a Detroit Diesel gasket set, and several extra seals and such for various things. I did all the work by myself, with no helpers.
Rear of Engine
The NATO engine had an aluminium bell-housing and a flat flywheel that would not take a clutch. The bell-housing size was a fair bit smaller than the bus SAE bell housing that the Spicer gearbox bolts to, and needed to come off and be changed to the bus bell housing. Same with the flywheel and clutch. The NATO engine has no accessory drives at all on the back. Installing the accessory drives for the power steering pump, air compressor and alternator meant that the engine plate had to come off. That meant that the gear train - idler gear, two cam gears and the blower drive gear - had to come off, along with the blower drive. Taking all that off the bus engine, stripping down the NATO engine, cleaning and re-installing all the extremely dirty bus engine parts was around a 100 hour task. Much of that was simply cleaning the bus parts so they could be painted and reinstalled. I rebuilt the clutch and installed a new pilot bearing in the bus flywheel. The main difficulty is not the complexity of the work, it’s the weight of the parts. You need a hoist to install the bell-housing and the flywheel, although you can install the clutch by hand.
Accessory drives
The NATO engine has no accessory drives at all. The bus engine uses the right hand cam (looking from the back of the engine towards the front) to drive the alternator pulley, the left hand cam to drive the air compressor, and an accessory drive in the far left position for the power steering pump. You have to install the power steering pump drive on to the engine plate before you install the plate itself. The cam drives are internally splined steel plates about ½” thick that bolt onto the cam gears after they are installed and timed.
Top of engine
Moving forward, the NATO engine had an engine pre-heat system installed. It injected a mist of diesel fuel under high pressure directly into the air box beneath the blower, and ignited it with a spark plug. It was removed and tossed, and various holes plugged. The injection mechanism is in the same port on the block that is used for the water plumbing on an after-cooled Turbo engine, as a point of interest, so the block on the NATO engine is compatible with after-cooling. The blower on the NATO engine is non-bypass, and according to Don Fairchild the turbo is an old design low pressure turbo.
Front of engine
At the front of the engine, the MCI engine cradle system uses a large round boss on the front gear cover as the front engine mount. The thermostat housings and the water plumbing are quite different as well. Rather than make new water plumbing and engine mounts I decided to change the front of the engine. That requires removing the water pump, the front cover, the balance cam pulley on the right hand cam (looking at the engine from the engine’s front, right is passenger side), the water pump drive gear on the left hand cam, and the front engine plate. You can now gain access to remove the left hand thermostat housing - the right hand one is right out there, very easy to change, but the left hand thermostat housing can’t be changed by a mortal unless the engine plate is off. Putting it back together is straight forward, just clean, paint and put the bus parts back on in the opposite order of taking off. One note is you can’t install the MCI engine cradle with the water pump in place.
Fuel System
The NATO engine had a different plumbing installation for the fuel lines compared to the bus engine. I changed over to the MCI system - fuel into the heads at the front on both sides, a cross-over from the left head to the right head at the front, and fuel out from a restrictor fitting at the back of the right hand head. The NATO engine had the cross-over at the back of the heads, and the restrictor fitting at the front of the right hand head.. I also used the MCI fuel filters and plumbing, which were spin-on type and mounted on the engine cradle. The NATO fuel filters were mounted on the front of the engine. The fuel pump was a slightly different model to the one on the bus engine - I am told it’s a high volume version and it has slightly different input and output port locations, so you need to adapt the fittings to suit. I installed an in-line electric priming pump, which worked beautifully when I started the engine for the first time.
Several of the fuel injectors were very sticky, I pumped solvent through them for several hours and they freed up. The NATO fuel injection system includes an external starting aid and a throttle delay system. The mechanical governor is a fairly normal automotive LS-DW type. If you don’t have Jake brakes to install, it can be used as is. If you have Jake brakes, you need to install the valve bridges, the fuel pipes and the Jake units following the instructions for that.
I took the fuel control tubes off the heads while doing this, so I did a complete rack set up after I put it all back together. If you didn’t disturb the rack, all you would have to do is go through it and check all the settings.
Oil System.
The oil system externals are quite different between the NATO engine and the bus engine. The NATO engine has a very large two row oil cooler designed to cool the hydraulic systems associated with the automatic transmission in the military vehicle. It also does not have an oil filter head, and the adaptor for the engine coolant into the block is different. All you do is take off all the oil cooler stuff off the bus engine, clean it, paint it, and install it on the NATO engine. The block is pre-drilled and tapped with all the holes you need, but as they are unused on the NATO engine you have to clean them and chase the threads. The 8V-71 block has several external oil line feeds. I used the front right hand block feed for the air compressor, the rear right hand block feed for the power steering pump drive, and the rear left hand side for the alternator and the turbo. The rear left hand side feed on the stock MCI setup was for the alternator and for the oil pressure gauge manifold. I drilled and tapped the oil filter head on the return side for an oil line to the oil pressure gauge manifold, so it now reads oil pressure directly after the filter.
The oil pump on the MCI bus engine was the standard scroll type pump housed in the front engine cover over the crankshaft nose. The NATO engine uses a different type of pump similar to the one found in the 12V-71, according to my manual, and it is mounted on the main caps and gear driven. The oil pan is deeper to allow clearance for the oil pump drive gear, and the bus oil pan will not fit. I used the NATO engine pan will just worry about the lower pan height on the back of the bus, and not drive over large rocks or down steep grades.
Intake/exhaust system.
The NATO engine has a turbocharger mounted on the back of the engine just about exactly where the air compressor is on the bus engine, so it has to be moved regardless. Different bus installations will put the turbo in different places. If your bus can have an 8V92T installed, the best solution is to get the exhaust manifolds and blower top from an 8V92 and use that whole setup - it should bolt right on. The MC-5C has a very low engine bay height, so I mounted the turbo on the drivers side of the engine, fabricated a completely custom exhaust to the turbo and then to the muffler, and fabricated a new blower top to take the pressurized air from the turbo. The turbo needs both an oil feed line of pressurized oil, and an oil drain line down to the pan. The NATO oil pan has two large pipe-threaded ports that you can use to drain the oil back, or you could drain it into the front engine cover if you did a top mounted turbo.
Summary
Those are the basic differences between the NATO engine and the MCI bus engine. Basically, the way to look at is that except for both being 8V-71’s they are about as completely different as they can be. To do the change right and use the stock MCI engine mounts I had to strip the both engines down to the block front and rear, and build it back up. As Clifford said when I started, it is a lot of work. But these engines are available new and as factory rebuilds, can be had way cheaper than an out-of-frame will cost, and you basically get to start with a brand new engine.
Costs
Here is the basic cost break-down of the project- note that I included the cost of fabricating the stands, the dolly and the crane I built to lift it with. It’s interesting that the engine cost was less than 25% of the total project cost. Also that the engine cost was less than the price of a good set of piston kits and liners. I bought the best gaskets, filters, etc, that I could buy, I replaced the air compressor while the engine was out, and yeah, I have now got a set of engine stands and a dolly for an 8V-71 that I sincerely hope I never have to use again - on my bus anyway!
8V-71T NATO engine $2,000
Gasket Kit $650
Bendix Tuflo 700 air compressor (rebuilt) $550
Pilot bearing $50
Throw-out bearing $125
Dolly (fabricated) $350
Stands (fabricated) $200
Crane/hoist (fabricated, chain host, trolley) $850
Fuel/air/oil lines and plumbing fittings $400
In-line fuel pump priming $65
Clutch springs and fittings $300
Seals and bits not included in gasket kit $100
Exhaust tubing/bends and fittings $850
Turbo flange and down-pipe to exhaust $200
Paint and cleaning supplies $100
Valve bridge machining $125
Oil and filters (oil, fuel, coolant) $250
Air filter and elbow, mounts $250
Throttle cable $325
Stuff I forgot $500
Total $8240
The end, for now… Next I have to drive it, and I figure sure as God made little green apples with a hundred more HP I’ll be upgrading the cooling system, there may be a different turbo in the future, and everyone says I need an intercooler…
Brian Evans
October 8, 2011
Ralph Peters (Ralph7)
Username: Ralph7
Post Number: 204
Posted From: 74.50.128.155
Posted on Saturday, October 08, 2011 - 6:03 pm:
Yes you need the aftercooler AND drive useing the temp guage! My 8-71TA gets warm at 65 on the level, and I need to lift, this is in a 77 TMC MC-8 with HT- 740 air trans cooler, and the rads are good.
The reason I went with the engine I have is my old 8-71N was very tired and needed a rebuild, this engine only needed 2 injectors and IF I do not hurt it probley not need another, hope!
Username: Joemc7ab
Post Number: 571
Posted From: 66.38.159.33
Posted on Saturday, October 08, 2011 - 8:02 pm:
Brian
Congrats on getting it all back together and running.I am sure it has given you a great sense of satisfaction. After all busnuts get their hands dirty once and a while and have to spend some dollars to keep their beasts going.
Username: Bigrigger
Post Number: 558
Posted From: 97.91.68.252
Posted on Sunday, October 09, 2011 - 11:31 am:
"You're a better man than I am Gunga Din". Well done and well blogged. I learned more in the 15 minutes I spent looking over your post than I knew in all the years I have owned 8 V 71 detroits in various vehicles. Thanks for sharing.
John
Post Number: 1556
Posted From: 76.4.122.151
Posted on Sunday, October 09, 2011 - 1:12 pm:
I am glad you did this instead of me LOL GOOOOOODDDDD JOB and thanks for the post,learnt a lot from it also
Gomer
Username: Bevans6
Post Number: 83
Posted on Sunday, October 09, 2011 - 2:08 pm:
That was really just the "this is a NATO engine, this is a bus engine, shake hands, return to your corners and come out fighting" post. I am also writing a blog type post on the story behind the conversion, I'll post that in a day or so.
I feel bad they are so long, though, I guess people can not read them if they don't want to!
Brian
Username: Luvrbus
Post Number: 1287
Posted From: 184.10.185.251
Posted on Sunday, October 09, 2011 - 2:29 pm:
Brian,fwiw some MCI 8's and 9's with 8v71's had the oil pump in the pan not on the front of the engine.Derrick Thomas here has a 8v71 n/a in his MCI with the oil pump in the pan
good luck
(Message edited by luvrbus on October 09, 2011)
Post Number: 1469
Posted From: 24.239.5.12
Posted on Tuesday, October 11, 2011 - 10:10 am:
Hey Brian,
Great posting! Would you consider donating this to BNO so everyone can reap benefit from it forever and ever?
Thanks.
Username: Bevans6
Post Number: 84
Posted on Tuesday, October 11, 2011 - 11:02 am:
Ian, that was what I hoped would happen, to be honest. Please use it as you can. I am preparing another document that is more the story of the build, rather than the bald things I changed on the engine outline. It has pictures in it. it will be in a WPS format as drafted. Can you do anything with it?
Brian
Post Number: 1470
Posted From: 24.239.11.34
Posted on Tuesday, October 11, 2011 - 10:38 pm:
Hi Brian,
If you can copy and paste it into a Wordpad or Notepad document and email it to me, that'd be great!
If it's just as easy to create it in either of those two Windows programmes, then you could also copy and past it directly onto a message on this bbs. I would capture it and delete the message, then put it in the archives all formatted and looking pretty!
If any of that makes sense to you, lemme know!
Thanks so much!
