Bill K. (165.121.83.149)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 26, 2004 - 5:58 pm: | |
I reinstalling my eng. and tranmission after the co. finally got it back together, I hope they did a better job this time. If you don't remember I had a tranmission failer after a total rebuild and only 3 to 4 hundred miles later and this was done by a allision shop. They repairded for no cost but they would not remover and install. and said that the cause was they updated the valve body and FORGOT to drill a hole which was needed to get oil to the plantary gears. guess no hole and burnt the gears Yes they did rebuild but what a lot of work and a total of 400 miles travel time to and from shop. I just hope they got it wright this time. any way I can't find my book so can anyone tell me how much oil in the powersteering and how about the cooling system. Iam putting in new Diesel antifreeze. This is a mc8 and I keep the bus heating system. Oh yes they forgot to send the hose from the steering pump to the bus, I have called and called with no response from the service boss. So I got a new one made and I did not get the bill yet but will probably be sixty to eight dollars. I took the hole unit to them eng and tran I thought that is the leastthey could do is seperate and put back together. |
