Derusting metal, an Experiment Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » November 2011 » Derusting metal, an Experiment « Previous Next »
Username: Dallas
Post Number: 792
Posted From: 98.20.59.175
Posted on Tuesday, November 22, 2011 - 8:06 am:
I've been collecting antique tools here and there for many years. Nothing very valuable but still some of them are kind of neat. I also have some antique bus parts that I've wanted to clean the rust off of.
I use to Use Phosphoric acid, derusto, naval jelly, along with sand paper and wire brushes and wheels. Mostly I wasn't satisfied with the outcome. Sand paper and wire wheels leave marks and the liquids don't always do a good job aside from being expensive so I tried a little experiment yesterday.
I grabbed my old 10a batter charger, some jumper cables, a couple pieces of angle iron, some clamps, an old plastic tub, some water and some Arm & Hammer washing soda, (Not Detergent).
My first victim was a heavy old rasp I got at a yard sale years ago and it was badly rusted.
I filled my tub with about a gallon and a half of water, added about 3 tablespoons of washing soda and set it out on the side porch.
The angle iron I cleaned off with a grinding wheel so it was shiny on all sides and ends these I put into the tub across from each other standing up with the top ends sticking out of the water.
I attached the positive lead of the battery charger to one and used the positive clamps of the jumper cables to connect them together.
The rasp I connected to the negative lead of the battery charger and placed it in the bottom of the tub.
After plugging in the charger and turning it on I watched the water. Soon bubbles started rising from the rasp as it began to cook a little bit. Not from heat, but because of the current passing through it.
I left it over night, checking it a few times and cleaning off he residue that built up on the angle iron anodes and making sure I still had good connections.
Here are the results:
Before: http://busconversionstuff.com/gallery/displayimage.php?pid=179&fullsize=1
After: http://busconversionstuff.com/gallery/displayimage.php?pid=181&fullsize=1
(Message edited by Dallas on November 22, 2011)
Username: Timb
Post Number: 638
Posted From: 66.165.176.62
Posted on Tuesday, November 22, 2011 - 9:08 am:
Good stuff Dal!! For the younger inexperienced ones like me what is washing soda and where do you get it????
Jim Sanders (Sandy)
Username: Sandy
Post Number: 125
Posted From: 69.199.96.250
Posted on Tuesday, November 22, 2011 - 9:09 am:
Dal how about me sending my bus frame up there clean it good and mail it back All Clean and NEW LOL JIM
Jim Sanders (Sandy)
Username: Sandy
Post Number: 126
Posted on Tuesday, November 22, 2011 - 9:12 am:
Tim you are not supposed to have rust LOL JIM
Username: Dallas
Post Number: 793
Posted on Tuesday, November 22, 2011 - 9:28 am:
Washing soda is available in your favorite emporium of victuals. The brand I used was Arm & Hammer. It comes in a big yellow box for about $4.00.
Washing soda is actually nothing more than sodium carbonate. NOT sodium Bicarbonate.
However, you can make sodium carbonate from sodium bicarbonate by spreading a thin layer of baking soda on a baking pan and putting it in a 305° oven for an hour or so.
Caution: If you do this, (electrolytic rust removal), make sure you have good ventilation.
During the process I have been told that the bubbles that rise from the anodes have a small concentration of hydrogen gas.
Jim, if you can get your bus frame in those little flat rate boxes I'll be happy to de-rust them!
You can also de-rust large pieces without a pan. Just use towels wetted with the solution and wrapped around the rusty part, then tie the anodes to the towels. It's probably not very efficient that way,but the more current or the stronger the solution or the closer the anode is to the cathode, the better the process will work.
Russell Beam (Rcbeam)
Username: Rcbeam
Post Number: 71
Posted From: 74.131.53.155
Posted on Tuesday, November 22, 2011 - 6:43 pm:
Dallas: I have never heard of such a thing as you just did. Does it have a name? Where in the world did you come up with such an idea?
Interesting indeed.
Username: Dallas
Post Number: 794
Posted on Tuesday, November 22, 2011 - 6:58 pm:
YEah Russ, it's called "electrolytic De-rusting".
I heard about it from a friend on another forum that restores old machinery, wood planes, saws, etc.
He has even used it to de-rust an old 1920's Ford engine block.
Looking around on the internet, I found a lot of "how-to's" and went from there.
http://www.oldengine.org/members/orrin/rustdemo.htm
http://www.rickswoodshopcreations.com/Miscellaneous/Rust_Removal.htm
Username: Dallas
Post Number: 795
Posted on Tuesday, November 22, 2011 - 7:04 pm:
Right now I have an antique Sargent 414 jack plane in the soup. I'll pull it out in the morning and see how it looks.
Bill 340 (Bill_340)
Username: Bill_340
Post Number: 159
Posted From: 75.224.117.199
Posted on Tuesday, November 22, 2011 - 7:59 pm:
Do you think, that maybe you could hook that same system to the front and back bumpers of an Eagle, that may just solve all the problems. Being a former Eagle owner I just had to say that........................
Username: Dallas
Post Number: 796
Posted on Tuesday, November 22, 2011 - 8:19 pm:
Probably not Bill, there has to be enough steel left to make a circuit. ;>}
Sam Summers (Greyghost)
Username: Greyghost
Post Number: 114
Posted From: 166.182.3.43
Posted on Tuesday, November 22, 2011 - 8:23 pm:
Dallas, How much do you want for the rasp?
Mines wore out and rusted...
Sam
Username: Dallas
Post Number: 797
Posted on Tuesday, November 22, 2011 - 8:32 pm:
Sam, they are easy to find at yard sales and flea markets, besides, a new one like mine is only $26, but they've been back ordered for 2 years.
Bill Holstein (Billmoocow)
Username: Billmoocow
Post Number: 164
Posted From: 24.21.114.17
Posted on Tuesday, November 22, 2011 - 10:55 pm:
Best info post i have seen in a long time! Thanks Dal. Very good info!
Username: Jack_fids
Post Number: 995
Posted From: 72.211.145.15
Posted on Wednesday, November 23, 2011 - 1:02 am:
Assumption:
Some of us still smoke Pot
some claim to not.
Using elec-tricmels
to dissolve FeO2 rot
makes me think
it may be the Beer...!
Next Week's
Mister Wizzard Farnworth will be
the Extraction of Hydrogen of HouseHold produced Methane
for fun & profit in your own Bus, a study in compression & pressure tankage .
Username: Dallas
Post Number: 798
Posted on Wednesday, November 23, 2011 - 8:10 am:
Hunh?
Jack, go get another glass of Mouse Milk and you should feel better.
Austin Scott Davis (Zimtok)
Username: Zimtok
Post Number: 485
Posted From: 173.166.209.1
Posted on Wednesday, November 23, 2011 - 9:45 am:
I've used this type of rust removal often over the years...
It is great for small parts that you don't want to loose the details of like you would if using a wire wheel or grinder....
You can put a bunch of small parts in a metal basket to save time.
