CaptBob (141.149.215.151)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, July 24, 2004 - 6:47 pm: | |
A few days days ago I posted that my ignition was not shutting the bus down. I have a 6V92 and HT748 with a Stone Bennett Air Shifter (LED Display). What I found was that the shift acuator on the transmission has a sensor board with contacts to tell the system what gear the tranny is in. Mine was dirty and had a broken contact. Only took about 1 1/2 hours to clean and repair. Everything works great now. Must had been confusing the system not knowing what gear it was in. Just wanted to make this post in case anyone else had the same problem. CaptBob cc661@yahoo.com |
Jim Ashworth (Jimnh) (172.130.231.196)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 25, 2004 - 8:13 am: | |
Thank you for posting this. Its not often we get to know the result of troubleshooting a problem. Jim |
mel 4104 (66.119.33.135)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, July 27, 2004 - 10:10 am: | |
i would also like to say thank you for posting the results of you finding that fixed every thing for you ,as Jim says there are a lot of posts but very few ever return with the answer that fixed the problem , it is sure nice to have you do this .. so thanks again mel 4104 |
