John Bessette (67.136.227.51)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, July 31, 2004 - 12:08 pm: | |
Could some of you tell me what it cost you to put in your Penisula windows on a 4106. I am thinking of two on the left and three on the right and maybe the drivers side and passenger side. Thanks John 4106 |
mclough (65.137.130.40)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, July 31, 2004 - 3:49 pm: | |
i recieved a quote from them for the drivers front and side windows $275 each and the big windows $475 |
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 05, 2004 - 1:50 am: | |
mclough thanks that sure sounds like a lot but if you want the nice windows I guess? |
John that newguy (199.232.240.78)
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 05, 2004 - 8:56 am: | |
Some help? http://www.peninsulaglass.com/ If you do a search here for "peninsula windows" or use "RV replacement window for m9" for the search, you should find quite a few more posts that will be of help. It appears the double-pane, tinted, sliding and screened "peninsula windows" do cost some $$ but they fit without modification into the existing opening. If you're doing the bus and don't want to re-side over exisiting window holes to use less expensive windows, then "peninsula" might be well worth the bucks. Those "less expensive" rv windows might not be too much less, either.. when all's said and done. No-one says you have to do all at the same time! Since they fit into the same frame opening, I can do one or two and wait until I hit the lottery to do another one or two. (hey....it's a plan) Smile, it gets easier! It does! |
