Generator Issues Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » December 2011 » Generator Issues « Previous Next »
Buddy Tennison (Buddyten)
Username: Buddyten
Post Number: 101
Posted From: 24.233.243.30
Posted on Sunday, December 11, 2011 - 7:44 am:
Gurus:
I have an Onan Marquis 7000 Generator. A couple of weeks ago, we used the bus, and it operated fine. Yesterday, took her on another little short trip, and the genny cranks and runs fine, but is not putting out any power. Checked all the breakers, etc, you know the normal stuff you would check.
Any suggestions on where to start looking for the problem?
Username: Jackconrad
Post Number: 1429
Posted From: 71.52.189.221
Posted on Sunday, December 11, 2011 - 7:45 am:
Loose Connections??
Username: Luvrbus
Post Number: 1327
Posted From: 184.10.159.32
Posted on Sunday, December 11, 2011 - 10:12 am:
Onan's are bad about the reverse current relay going bad or if you lose the shunt field ground it will stop producing power
good luck
Username: Pd41044039
Post Number: 725
Posted From: 184.0.13.120
Posted on Monday, December 12, 2011 - 9:17 am:
Onans will not stay running if they are not making A/C power. They will run until you let go of the start switch. If it continues to run, I would look at a breaker or some issue downstream of the genny.
Post Number: 1630
Posted From: 97.225.122.5
Posted on Monday, December 12, 2011 - 8:16 pm:
....AND....Onan breakers may indeed need to be, well,..."replaced"...:-)...my experience. Don't know why.
FWIW
Derrick Thomas (Thomasinnv)
Username: Thomasinnv
Post Number: 38
Posted From: 72.171.0.149
Posted on Monday, December 12, 2011 - 9:15 pm:
Jim Bob that is not true of ALL onans. The older ones do in fact need to see output voltage to keep running, but the newer fully electronic controlled units will run with no output voltage. I have repaired a few that ran but put out no power so I know this to be true from experience.
Post Number: 727
Posted on Tuesday, December 13, 2011 - 10:15 am:
Derrick, sorry about that. I obviously over reached my knowledge base. I never get to work on NEW stuff.
Post Number: 39
Posted From: 72.171.0.146
Posted on Tuesday, December 13, 2011 - 6:03 pm:
Over reaching my knowledge base is something I am found to be guilty of quite often. LOL.
