GM Fan Drive Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » December 2011 » GM Fan Drive « Previous Next »
Username: Luvrbus
Post Number: 1326
Posted From: 184.10.159.32
Posted on Sunday, December 11, 2011 - 9:03 am:
Any of you guys know why a the fan drive would have a 1/2 end play,I tore in down and the only problem I can find it looks like a problem with Torus but the manual is not clear on the end play.
This one moves so much on the fan hub drive somebody has drilled and tapped the housing and installed screws to keep the seal from running out you guys got any answers
Bill Gerrie (Bill_gerrie)
Username: Bill_gerrie
Post Number: 584
Posted From: 216.198.139.38
Posted on Sunday, December 11, 2011 - 10:57 am:
Luvrbus
I can email you the parts blow up. The only thing I could see was if the snap ring has let go or the housing that holds the front bearing is worn.
Bill
Username: Luvrbus
Post Number: 1328
Posted on Sunday, December 11, 2011 - 11:07 am:
The snap ring is there Bill and thanks but I have the manual with the parts blowup,I am thinking it has the wrong bearing but just a guess I don't have the original parts number for the bearing to cross over
thanks again even the guy at Luke's cannot answer this one
(Message edited by luvrbus on December 11, 2011)
Post Number: 585
Posted on Sunday, December 11, 2011 - 11:28 am:
Luvrbus
The bearing looks like quite a thick one in the parts blow up. If the housing is okay with a lip behind the bearing and the snap ring in front of it which should stop any movement you might be right. Somebody may have installed the wrong bearing. Pull it out and go to a bearing place. They can look it up based on dimensions. You may need a double race type to give it the width to fill in the space. Just a thought.
Bill
