PD4106 battery ground question Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » December 2011 » PD4106 battery ground question « Previous Next »
Jim Rink (Fakeguy)
Username: Fakeguy
Post Number: 185
Posted From: 96.11.208.103
Posted on Monday, December 12, 2011 - 10:52 pm:
Currently, my battery ground is on a bolt running through the body where it connects to the starter ground. The bolt runs through the body in front of the left rear wheel into the battery box where the cables are connected. Thus, the aluminum body serves as the ground.
My question is if anyone has similar and if they have had any starting problems due to bad ground with a similar configuration: Or is a ground to the steel on the engine cradle, for example, a better idea.
Just curious as to how others have grounding configured. BTW 2 12 VOLT batteries connected to one cable.
Thanks in advance
Username: Pvcces
Post Number: 1390
Posted From: 141.0.9.60
Posted on Tuesday, December 13, 2011 - 12:43 am:
Jim, we have our battery ground cable running directly to the ground post on the starter; if I recall right, there is a heavy jumper between the ground stud and the engine block, which is needed for the alternator output.
If you use the body for a ground and the cable to the starter has a high resistance connection, starter current will take the easiest path to the starter. That will be through the axle and drive shaft.
After some arc welding goes on in those components, you get to do some expensive repairs.
That's the way that I see it.
Tom Caffrey Pd4106-2576
Suncatcher
Ketchikan, Alaska
Post Number: 1629
Posted From: 66.82.162.14
Posted on Tuesday, December 13, 2011 - 7:09 am:
The coach battery ground to the frame is a PM job.
It should be bolted with COPPER bolts , nuts and washers , as iron, SS or even bronze do not have the ampacity of pure copper.
Yes it has to be cleaned every 6 months or so due to the dissimilar metals.
Not cleaning it can (will) cost the voltage regulator in time.
(don't ask,)
FF
Brian Evans (Bevans6)
Username: Bevans6
Post Number: 109
Posted From: 67.71.38.16
Posted on Tuesday, December 13, 2011 - 8:25 am:
I never really thought about it before, but on my bus (MCI) the battery ground is to a large stud welded to the steel chassis tubes in the front battery compartment, and the engine ground is from the starter motor stud to a large stud (1/2" to be exact) welded to the engine support frame part of the chassis. So the ground path is through the steel part of the monocoque structure. Steel studs, not copper, fwiw. The alternator body is similarly grounded, but with smaller wire and stud size.
FWIW, since I know there are differences between GM practice and MCI practice.
Brian
Austin Scott Davis (Zimtok)
Username: Zimtok
Post Number: 487
Posted From: 173.166.209.1
Posted on Tuesday, December 13, 2011 - 4:06 pm:
My 4104 still has the positive ground.
Two 8-D batteries connected to a copper bolt in the aluminum body. Each battery has a cable connected to this bolt.
The engine/cradle has a ground strap to the aluminum body to a bolt I assume is copper.
I have often thought that a cable run between the two ground bolts may help for a better connection. But as I have never had a problem with these ground connections and the bus starts fairly easy I have not thought too hard on it.
I do clean the ground connections at the bolt connected to the body in the battery bay about twice a year along with the other battery connections.
Jim Rink (Fakeguy)
Username: Fakeguy
Post Number: 186
Posted on Tuesday, December 13, 2011 - 6:33 pm:
Hey...thanks to all. I suspected that it would be a good idea to make a better ground set up and your responses verify my guess.
Username: Gusc
Post Number: 1409
Posted From: 173.202.16.250
Posted on Tuesday, December 13, 2011 - 6:56 pm:
The t5hing to note about your post is that the bolt goes "through" the bulkhead. This means the batt ground post is directly connected to the starter ground. All you need is to be sure the engine is grounded to the starter and I'm sure the starter mounting bolts do this very well.
However, you do need a good body to engine ground somewhere to make all other stuff work well.
If the bolt running through the bulkhead has clean contacts from the bolt nuts to the bulkhead you have that ground.
I see no problem if this connection is clean.
Post Number: 2173
Posted From: 174.89.179.225
Posted on Tuesday, December 13, 2011 - 11:10 pm:
I am quite fond of the copper anti-seize as a treatment for my ground connections.
Makes a mess, but there's little to no corrosion issues for a long, long time.
Comes in plastic bottles with the brush built into the lid.
Permatex is only one brand.
Username: Pd41044039
Post Number: 728
Posted From: 184.0.13.120
Posted on Wednesday, December 14, 2011 - 10:37 am:
Buswarrior, I use anti sieze on cable connections as well. I did mine 11 years ago with no problems since. I also use a liquid product called Corrosion Block which I spray on the control wire terminal boards, etc. This stuff, designed for marine use, creeps into each connection & stays for nearly ever if not exposed to weather. They also make a Corrosion Block Grease which I use in light bulb sockets & plug connectors.
Username: Oonrahnjay
Post Number: 709
Posted From: 76.4.16.189
Posted on Wednesday, December 14, 2011 - 10:53 am:
Jim Bob - I did a quick Google search; here's one thing I found:
http://www.reddenmarine.com/marine-supplies.cfm/lubricants-corrosion-protection/corrosion- block-20012/corrosion-block-12-oz-aerosol.html
It's probably possible to find a lower price, cheaper shipping near you, etc. but this is at least one availability point.
HTH, BH NC USA
Username: Jack_fids
Post Number: 1001
Posted From: 72.211.145.15
Votes: 2 (Vote!)
Posted on Wednesday, December 14, 2011 - 1:58 pm:
MugShot of the usual suspect,
after a bit of elbow grease & mouse milk
feel free to have a look here..
https://picasaweb.google.com/jackfids/4106Album#5534493304915817970
...fwiw
Post Number: 1596
Posted From: 76.4.123.74
Posted on Wednesday, December 14, 2011 - 10:55 pm:
BRAGGER!! NA NA NA NA Good job tho BRAGGERERT!!
Gomer
Post Number: 729
Posted on Thursday, December 15, 2011 - 6:18 am:
Bruce, here is a link to the product website:
http://www.learchem.com/products/corrosion-block.html
It's not that expensive because you don't use a lot. They offer a non aerosol pump (plastic spray applicator with built in air pump) I like that cause I can refill it, see how much is in it and you never run out of propellant. I buy the stuff in the quart bottle which lasts years but also try to score some of the little free sample tubes & tiny bottles at boat shows, etc.
Username: Jack_fids
Post Number: 1002
Posted on Thursday, December 15, 2011 - 12:48 pm:
Gomer....
you're just jealous because my brass fasteners shine
and they are larger than most......
not that they get used anymore or less than they used to ....I actually think you took money, from someone whose fasteners are smaller & not as shiney, to say that in public tho....
(I hope Les paid you in greenbacks & not maple leafs)
Post Number: 711
Posted on Thursday, December 15, 2011 - 1:28 pm:
Thanks, Jim. Appreciate it. Since our tea drinking cousins across the ocean apparently never heard of "bi-metallic corrosion" or thought of how to prevent it, I'm afraid that I'll need more than a little! I had noticed that the Redden Marine site shows different sizes and container styles. This sure looks like one of those "ounce of prevention" things that you're sure glad you took care of on dark rainy nights.
Username: Gusc
Post Number: 1412
Posted From: 173.202.19.248
Posted on Thursday, December 15, 2011 - 8:13 pm:
Let's see, brass, steel, copper, Al and electricity!
This should make a nice corrosion battery!!
Username: Joemc7ab
Post Number: 592
Posted From: 66.38.159.33
Posted on Thursday, December 15, 2011 - 8:50 pm:
Maple leafs are at least "real" money, unlike some stuff that passes for and is called "money"
les marston (Les_marston)
Username: Les_marston
Post Number: 430
Posted From: 68.151.225.213
Posted on Thursday, December 15, 2011 - 9:07 pm:
It never ceases to amaze me how I get into the middle of these things.
Fids!
Beware the Canadians are watching you!
And no, If the whole world IS out to get you it is no longer JUST paranoia
Post Number: 712
Posted on Thursday, December 15, 2011 - 9:17 pm:
Gus, you just passed your test - you are now qualified to be a British vehicle engineer!
Username: Gusc
Post Number: 1413
Posted From: 173.202.24.101
Posted on Friday, December 16, 2011 - 6:10 pm:
Bruce,
I now own two British vehicles and owned another years ago but I never found such a mess as this.
However, I have found some unique and interesting things with them!!
Overall, though, I love them but am partially blind to their faults.
Username: Dallas
Post Number: 813
Posted From: 75.91.200.113
Posted on Friday, December 16, 2011 - 6:57 pm:
Gus, if you need it I think I have a spare bottle of Lucas Smoke around here somewhere.
Post Number: 714
Posted on Friday, December 16, 2011 - 9:08 pm:
Dal - all of us who have British vehicles have lots of that already. And plenty of leaks for it to get out.
Gus - you know what I'm talking about. Working for two British vehicle manufacturers for 20 years was "character building".
Username: Jack_fids
Post Number: 1005
Posted on Saturday, December 17, 2011 - 11:43 am:
A friend of mine once bought a Triumph TR-6.
On the way home he had to stop for a traffic light.
While he was there a large dog relieved himself on the rear tire.
When the light turned green the entire Lucas electrical system failed & it needed to be towed back to the dealer...it was starting to smolder as the tow truck pulled away....
Username: Gusc
Post Number: 1414
Posted From: 72.161.175.147
Posted on Saturday, December 17, 2011 - 6:04 pm:
Jack,
That was because British cars have positive ground and the tires are conductive!!
Username: Jack_fids
Post Number: 1006
Posted on Monday, December 19, 2011 - 10:02 pm:
...and that's because the engines they put in them was used to pulling plows thru gardens & not externally seamed small cars on Motorways...
Funny the tires were conductive & not the wires from the Lucas Electrics..funny if you DINT own one !
