FAST FRED (38.26.182.49)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 05, 2001 - 6:10 am: | |
"It has been my understanding (from what I 've read) that parts are getting harder and harder to come by for the 410X....." It is true that your local truck stop wont have much BUS SPECIFIC stuff for a GM,, but that goes equally well for ANY bus, even a brand new one. Almost any part can be had by mail , or with a phone call, so the trick {HOPEFULLY} is preventave maint. The parts in most coaches are VERY robust , and die a slow death. IF you keep most any coach in good mechanical condition, the reward is no tow rope rides. D'a book is very specific on how to maintain every coach , so its only a matter of going thru the coach to SERVICE, not necessarily replace everything . This takes time and dirty hands , but not big cash or very special skills. IF you replaces the front brakes in a 40 Ford or 60's VW its mostly the same,, just a bit different , and a whole lot bigger stuff. But a wheel bearing is a wheel bearing , weather its an 1 1/2 in diameter or 4 in. Leave home with a well serviced coach and you will usually get where your going. A great advantage of a DD is the fact that they advertise their ill health , usually for a long time , before giving up. The old GM make a fine conversion , as the early monocoque bodies are extremly strong , with almost all alluminum construction , and only a small amount of steel to worry about. You also get the floor leignth of most 40 ft coaches in a 35 GM, due to the V drive. Finally as this V drive style unit is being constructed today , as transit . When the transits hit the scrap heap [ not from old age ,, but from unlimited "free" cash for mess transportation from Uncle Sucker} the new modern drive trains , engine , tranny ,front and rearaxles , huge transit brakes will all be had , at auction for a grand or two. Drive it home , spend a couple of weeks changing over , an item at a time , to stay drivable. AND you now have an almost indestructable coach , that will not disolve , with a year 2000 running gear !! For some dirty hands , and a bit of time. The engineering will be newer and better than most of the busses running now. Parts will STILL not be at a truck stop tho. The recent crash of coach prices . makes the cost of a shell almost meaningless in the cost of the conversion. A great shell can be had for $5000 to $10,000 , so there is NO reason to use a Skoolie as a conversion. The disadvantages outweigh the cost ? advantage . Only exception is someone that NEEDS a short Skoolie w/ 4 wheel drive, coaches are not at their best in rock climbing on a dirt path. FAST FRED |
