Nitrogen in tires Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » December 2011 » Nitrogen in tires « Previous Next »
Bill 340 (Bill_340)
Username: Bill_340
Post Number: 171
Posted From: 75.203.51.77
Posted on Wednesday, December 21, 2011 - 2:53 pm:
well I know this will cause controversey but its what I DID and these are my results... This week I had a young man come to my home with a van equipped with a Complete nitrogen system he pumped the air from my VAN tires, he then replaced it with nitrogen, Well the next day I had to travel I-4 to clearwater fl, and back ofcourse, the van never rode so quiet, I was on black top, concrete and plain rough road, very quiet compared to past road noise, Next day to orlando and back again less road noise, now they tell you that it helps increase fuel mileage, Maybe it does maybe not didn't check that yet, Very satisfied with what I have found. SO I called him today and convinced him to come to the arcadia rally, he only has one day he can make it, and that is Dec 30, so if anyone wants to make sure he will have time to do their unit, I am sure he would appreciate a heads up, so he can judge his time, thanks and we will see you in Arcadia, His name and number is Nitro Tire--Chad Smith- 863 412-0177
Username: Luvrbus
Post Number: 1334
Posted From: 74.33.2.184
Posted on Wednesday, December 21, 2011 - 3:09 pm:
I use nitrogen in the Lexus but found it didn't help any on the 12r 22.5's on the bus,fwiw Cosco will do that cost me 20 bucks there
good luck
Username: Pd41044039
Post Number: 733
Posted From: 184.0.13.120
Posted on Wednesday, December 21, 2011 - 3:53 pm:
Have used nitrogen in our Jetta tires. Got 80K miles out or 'em. One feature of the nitrogen is that it supposedly does not expand & contract as much as air so the tire keeps it's profile or shape no matter hot or cold.
I'm a believer.
Sam Summers (Greyghost)
Username: Greyghost
Post Number: 118
Posted From: 166.182.3.68
Posted on Wednesday, December 21, 2011 - 5:20 pm:
I use Helium, it makes my Pickup lighter and the songs on the radio all sound like the chipmunks Chip & Dale
Username: Oonrahnjay
Post Number: 716
Posted From: 76.4.16.189
Posted on Wednesday, December 21, 2011 - 5:53 pm:
Jim, in my Jetta sedan, I used 79% nitrogen and got 87K out of the stock Michelins. There must be something to this!
Username: Bigrigger
Post Number: 574
Posted From: 97.91.68.252
Posted on Wednesday, December 21, 2011 - 6:19 pm:
LOL @ SAM
Username: Jackconrad
Post Number: 1436
Posted From: 71.52.189.221
Posted on Wednesday, December 21, 2011 - 6:41 pm:
Sam,
Since you are using helium, does it make your coach lighter, thereby increasing your mileage?
Username: Greyghost
Post Number: 119
Posted From: 166.182.3.58
Posted on Wednesday, December 21, 2011 - 7:04 pm:
Jack,
Since using Helium, I float therefore I have to use Jet A, not cost effective but great life on tires except for the landings, have to use a tail hook
Kevin Baxter (Bus_boy)
Username: Bus_boy
Post Number: 39
Posted From: 74.100.213.9
Posted on Wednesday, December 21, 2011 - 9:05 pm:
Oh Brother!!! lol!
Kevin
Austin Scott Davis (Zimtok)
Username: Zimtok
Post Number: 489
Posted From: 173.166.209.1
Posted on Thursday, December 22, 2011 - 11:44 am:
I put a mixture of water and antifreeze in my tractor tires for better traction....
Post Number: 734
Posted on Thursday, December 22, 2011 - 2:05 pm:
That's got to be a LOT of antifreeze to fill tractor tires. I think I would offer to take used antifreeze away from some big truck shop to get it free. Won't matter if you mix brands or anything.
Post Number: 717
Posted on Thursday, December 22, 2011 - 2:06 pm:
@ Jim Bob - That's "road-holding weight". Works every time.
Jim Wallin (Powderseeker01)
Username: Powderseeker01
Post Number: 123
Posted From: 97.96.60.12
Posted on Friday, December 23, 2011 - 6:45 am:
Oxygen and nitrogen are neighbors on the periodic table. The difference between the two as a mechanism to inflate tires can't be distinguished outside of a laboratory. As a means to extract your cash from your pocket, the research indicates better performance. The lottery can do as well with a better possibility of payback. As the lowest resident of the periodic table, helium would be a poor choice because the molecule is much smaller and therefore able to escape from your tires much more quickly than the other two.
Post Number: 1632
Posted From: 67.45.7.143
Posted on Friday, December 23, 2011 - 6:52 am:
For our "new" 1956 bus ,
we are looking for a source of 1956 air to have matched air in the tires.
FF
Jorge Martinez (Foohorse)
Username: Foohorse
Post Number: 613
Posted From: 174.252.163.188
Posted on Friday, December 23, 2011 - 1:41 pm:
Fred isn't the air and water Billions of years old? I was thinking of filling my tires with nitrous oxide. Better top speed? Sorry Bill. JIM. anyway Sam started it :-)
Post Number: 736
Posted on Friday, December 23, 2011 - 3:06 pm:
I never suggested better top speed. But Bruce & I (and a lot of folks on the internet if you care to look) ARE suggesting longer tire life, both in terms of wear and in terms of tire rot. While most of us won't ever wear out a new set of bus tires (I wish!), we may have them long enough to have to replace tires that have new tread but are aged out. Research what others say as to oxygen's effects on rubber.
They also mention an approx. 3% gain in fuel mileage because the tire stays at optimum inflation longer. (Nitrogen does not expand or contract as much as plain air.) They were talking about tires that excede 100 degrees. My bus tires run at about 140 in summer, measured by heat gun. My toad has been as high as 154. Sounds like that could benefit us. Nitrogen also takes longer to leak out (larger molecule) so your tires are less likely to be underinflated.
Just sayin.....
Post Number: 1437
Posted on Friday, December 23, 2011 - 6:04 pm:
Jim,
I have always heard 7 years for the life of a tire on our coach. Have you seen any reports on how much the life can be extended if the tires are always fillled with N from new installation? Jack
Tony LEE (T_lee)
Username: T_lee
Post Number: 92
Posted From: 59.154.42.140
Posted on Saturday, December 24, 2011 - 6:52 am:
Confirmation bias - an insidious mental condition that not only makes one ecstatically satisfied with anything bought that costs an unreasonable amount of money, but also causes an uncontrollable urge to get others to do likewise.
Username: Greyghost
Post Number: 120
Posted From: 166.182.3.156
Posted on Saturday, December 24, 2011 - 12:23 pm:
Fred
My sister was born in 1956, I'll have her start bottling her air, sometimes it's even hot air.
Sam
Username: Foohorse
Post Number: 614
Posted From: 67.191.6.239
Posted on Saturday, December 24, 2011 - 11:33 pm:
Jim I understand the science, but don't most of the tires used on our buses rot from the outside in due to ultra violet, Oxygen free radical damage, and I don't mean knife wielding hooligans. I bought a set of tire covers but unless I can place the bus in a vacuum the oxygen is going to contact the tires.
Username: Chessie4905
Post Number: 2214
Posted From: 71.58.71.157
Posted on Sunday, December 25, 2011 - 9:45 am:
With all those tire plies on a bus tire, air leakage isn't much of a problem. Spend the money on a good brand of tire pressure monitors instead.
Post Number: 1495
Posted From: 24.239.11.34
Votes: 2 (Vote!)
Posted on Sunday, December 25, 2011 - 4:56 pm:
Fewer than 60% of people check their vehicle tire pressure regularly.
Nitrogen doesn't support combustion, while the 21% oxygen in air does. (The other 78% is nitrogen anyway, with 1% of a bunch of other stuff) (and that's about the only difference in the use of oxygen and nitrogen). Whoopdie-doo, no tire-fueled fires.
Therefore, check & adjust your tire pressure often. It'll save you a few bucks you can otherwise use for diesel, and you won't have to put up with those hideous green valve caps :~)
Post Number: 1635
Posted From: 69.19.14.28
Posted on Monday, December 26, 2011 - 7:49 am:
While the color of the valve CAP may be subject to personal preference, the choice of VALVE STEM is not.
These are color coded by the heat they can stand , be sure not to have bicycle valves in your bus !!
FF
Post Number: 719
Posted From: 98.70.122.186
Posted on Monday, December 26, 2011 - 8:19 am:
Fred - what colors are available and what does each color specify. Mine are bare copper (or brass) - what temp are those?
