Removing oil cooler Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » August 2004 » Removing oil cooler « Previous Next »
Brian (Bpo) (63.153.37.174)
Posted on Tuesday, August 17, 2004 - 5:07 pm:
I need help removing my oil & trans cooler from my 6v92. I have all the bolts out from the side and all clamps are loose, but it will not budge.
Thanks
Brian.
JImmci9 (209.240.205.68)
Posted on Tuesday, August 17, 2004 - 6:32 pm:
if you have the double-double plate style cooler... like for the engine and allison, there are trapped bolts behind the front cooler assy.... BE VERY CAREFUL when you put it back together... TAKE SPECIAL NOTE OF THE SHIMS behind the cooler.. if you don't put back the correct shims, YOU WILL BREAK the cooler... and it's BIG $$$$....email me at jimcat2@webtv.net if you need help...
