8v92 will not start unless you put a ... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » August 2004 » 8v92 will not start unless you put a shot of WD 40 « Previous Next »
carl mitchell (Carlmm) (66.44.246.102)
Posted on Thursday, August 19, 2004 - 7:54 pm:
This a 8v92 DDEC could it be an electrical or computer problem.
I checked the fuel filters they are OK. Throught might be air in the primary filter area.
It will run great after ether in air intake but let it set for a hour or more it will not restart.
Need Help
Carl
JimStacy (209.247.222.113)
Posted on Thursday, August 19, 2004 - 7:59 pm:
Do you have restrictor oriface in the return line and a check valve, preferably one in supply line and one (Spring loaded type) in return line?
Jim Stacy
TWO DOGS (4.227.118.105)
Posted on Thursday, August 19, 2004 - 8:43 pm:
if the engine is turning over,you don't have an electrical problem...diesels have no points, or plugs or distributor....it IS a fuel problem....do like I do...what have I done since it ran good...
Jimmci9 (209.240.205.68)
Posted on Thursday, August 19, 2004 - 9:12 pm:
2d.... this particular engine is electronic... ddec... that means computer controlled...so it might still "turn over".. even tho it won't run... suggest that you take a look at your fuel filters.. if they're dry, after sitting, it means a fuel line has a leak.. allowing fuel to drain bacl to the tank... if you still have prime, it may be electronic... in which case, you need a "reader" to scan the computer
John that newguy (199.232.240.244)
Posted on Thursday, August 19, 2004 - 9:29 pm:
Are there glow plugs in that model? Preheater?
If a shot of ether gets it started....
Gary McFarland (Gearheadgary) (68.79.120.182)
Posted on Thursday, August 19, 2004 - 9:47 pm:
when I was enduring my tale of woe in SLC, there were three others in the service-writer are for work when I was there.
All three for DDEC problems.
(Ether gets it started 'cause the injectors ain't injectin')
Gary
Robert G. Williams (24.70.229.63)
Posted on Thursday, August 19, 2004 - 11:10 pm:
DDEC's require a minimum voltage for the computer to "open" the fuel. I have 6V92DDEC2 that will, after a night of dry camping, turn over relatively quickly, but not fire. The reduced voltage is not enough to power the electronics properly. They need something in the neighborhood of 11 volts while under starter load. This happens after dry camping for a night (I inherited the electrical system). Running the battery charger with the generator provides a quick start.
Rob
James Maxwell (Jmaxwell) (66.81.51.198)
Posted on Thursday, August 19, 2004 - 11:19 pm:
Rob: I would seriously consider the quick addition of an isolated house battery bank. I think your 11 volt minimum spec. is correct. I presume that to be At the Computer. Mine starts at the touch of the key but I once ran them down after a 3 month sit and at 22.5 on the guage it would turn over (barely) but not fire.
Posted on Thursday, August 19, 2004 - 11:23 pm:
James: I agree wholeheartedly. That's next on my list of reno's.
BrianMCI96A3 (208.17.77.130)
Posted on Friday, August 20, 2004 - 9:29 pm:
no glow plugs in a two stroke Detroit Diesel...
TWO DOGS (63.156.216.17)
Posted on Friday, August 20, 2004 - 10:18 pm:
no fuel either
