Post Number: 600 Registered: 6-2004 Posted From: 66.38.159.33
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 14, 2012 - 7:02 pm: | |
I finally have the XL in the busbarn, and if the problem is what Cliff suggested (cracked head) can a head be removed and reinstalled without taking the engine partway out and have it supported on a gurney. Not sure which is the easier way to go. Looking for advise from some that may have done it. |
Post Number: 1357 Registered: 8-2006 Posted From: 184.12.188.147
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 15, 2012 - 8:40 am: | |
It is not a hard job Joe I use a little shop crane Prevosts have a lot more room than a Eagle. You will need a set of head guides to reinstall you can buy those from www.monacotool.com for 30 dollars if the link doesn't work Monaco Tools fwiw I would not try and make the guides from head bolts. The torque and turn method on the head is almost impossible to do with the engine in the bus so I use 230/250 ft lbs works for me good luck (Message edited by luvrbus on January 15, 2012) (Message edited by luvrbus on January 15, 2012) (Message edited by luvrbus on January 15, 2012) |
Post Number: 603 Registered: 6-2004 Posted From: 66.38.159.33
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 19, 2012 - 10:09 pm: | |
Cliff Finally got the oil pan off. It took a few days for the gooye mess to drain out of the oilpan. I collected about 16 gallons. I have some fibre pieces in the oilpan, and looked in the manual to see where they might have come from, but I am not sure as yet. Would appreciate a call, my number is in the profile. Thanks Joe. |
Post Number: 1360 Registered: 8-2006 Posted From: 184.10.153.249
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 20, 2012 - 6:23 am: | |
From the steering pump drive Joe nothing to worry about 20 bucks from Luke I'll give you a call later today |
Donnie Daugherty (Dr_detroit)
Registered Member Username: Dr_detroit
Post Number: 30 Registered: 3-2008 Posted From: 98.145.204.65
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 20, 2012 - 5:32 pm: | |
Joe, I'm not sure how far you are planning to go with your repair but if you had lots of coolant in your oil, I would check the bearings. The coolant can cause the babbitt to fail and leave gaps in the bearing surface. The mains especially. I hope everything works out ok. Donnie Daugherty Enterprise Alabama PD4106-2772 |
