Bill Holstein (Billmoocow)
Registered Member Username: Billmoocow
Post Number: 172 Registered: 5-2009 Posted From: 24.21.114.17
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 20, 2012 - 11:40 pm: | |
Took all the clearance lights off the top front of the bus and re-sealed. Still leaking when it rains! What the frick? |
les marston (Les_marston)
Post Number: 439 Registered: 1-2010 Posted From: 68.151.225.213
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 21, 2012 - 12:36 am: | |
check the seam where the cap and the main roof join |
Post Number: 173 Registered: 5-2009 Posted From: 24.21.114.17
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 21, 2012 - 1:26 am: | |
I did. |
Scott Crosby (Scott_crosby)
Registered Member Username: Scott_crosby
Post Number: 61 Registered: 12-2011 Posted From: 166.147.102.144
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 21, 2012 - 6:00 am: | |
Screw holes? |
Post Number: 1656 Registered: 10-2006 Posted From: 67.238.59.158
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 21, 2012 - 6:19 am: | |
The sealants that come in a roll, as sold at the RV places are thick enough to seal any differences between the light and the structure. The plastic lens should have some sort of seal between it and the lamp fixture. If it can be replaced , using the same RV sealant , with some trimming will work. The joy of the RV stuff is it is not glue (5200) and not perminant , so stuff can be removed and re bedded as required. FF |
Post Number: 2227 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 21, 2012 - 8:10 am: | |
where exactly is the water dripping from inside? Does the coach have to be moving for it to leak. How heavy is the dripping? |
Post Number: 174 Registered: 5-2009 Posted From: 24.21.114.17
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 21, 2012 - 11:35 am: | |
It is leaking where the destination sign is. It is not leaking as much as it did but still does. May have to re-tackle next spring. I will leave a tarp over top for now. |
Post Number: 1444 Registered: 11-2005 Posted From: 173.202.4.54
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 21, 2012 - 2:55 pm: | |
Windshield may be leaking, sometimes it is hard to tell just where the leak is. |
Post Number: 1665 Registered: 7-2006 Posted From: 97.224.141.158
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 21, 2012 - 7:42 pm: | |
A bit of silicone/caulk/PL might be worth the effort and time.....in the meantime. It comes off, with a bit of mineral spirits, acetone,etc. FWIW RCB |
Post Number: 2232 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 22, 2012 - 8:46 pm: | |
With some plastic and duct tape, you could isolate different parts to pinpoint the leak area. |
