Peter Broadribb (Madbrit) (67.136.109.174)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 10, 2004 - 1:39 pm: | |
Does anyone have the correct name for the following tool description, also where I can obtain one from: It is a pair of pliers, but has 3 prongs sticking out out 90 degrees to the handles. When you squeeze the handles the 3 prongs part evenly, I think the outer 2 move away from the fixed top middle one. This was originally designed to expand rubber insulating sleeves about 1/2" long which would be put onto the wire prior to soldering a terminal on and then the sleeve would be slid down the wire over the soldered joint after it had cooled. Peter. |
Robert Wood (Bobwoodsocal) (4.46.108.207)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 10, 2004 - 1:48 pm: | |
I'm stumped! Sounds like a cool tool tho, hope someone else knows the name- I want one. Bob |
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 10, 2004 - 2:00 pm: | |
I suspect shrink tubing has probably made such a tool and rubber sleeving obsolete. Richard |
Peter E (Sdibaja) (208.57.14.228)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 10, 2004 - 2:18 pm: | |
sounds like what we used to slip rubber bands on crown jewels of the little boy sheep... we never had a name for it |
TWO DOGS (65.179.201.35)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 10, 2004 - 2:20 pm: | |
sounds like....pardon the french....when you put tight rubber bands on male sheep to make them not rams anymore...try a veternary supply,or farm supply,GEBO'S ...T.S.C. |
madbrit (67.136.109.174)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 10, 2004 - 2:35 pm: | |
Guys, thanks, It would be similar but smaller as it has to have a rubber sleeve with a tiny hole slid over the prongs prior to expansion and it only goes to about 1" diameter. Peter. |
TWO DOGS (63.185.97.58)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 10, 2004 - 3:32 pm: | |
this IS TINY...the rubber band shrinks to NOTHING when released... |
madbrit (67.136.80.237)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 10, 2004 - 4:00 pm: | |
The tools I looked up for animals are nothing like I am searching for, this has the prongs at 90 degrees to the handles and the prongs are about 1" long for the sleeve to slide up and be stretched the whole length, not a rubber band. The prongs are less than 1/8" total diameter when closed. Peter. |
Rob Williams (24.70.229.63)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 10, 2004 - 4:07 pm: | |
http://www.hilltop-products.co.uk/sleeve-expanders.htm |
Glenn (166.102.69.41)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 10, 2004 - 4:09 pm: | |
Hey Fellas, I'm not sure what the tool is that Peter is describing, BUT the tool that Two Dogs is talkin' about is called "emasculators". I've had the opportunity to use them on calves and goats over the years. Glenn |
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 10, 2004 - 4:18 pm: | |
Rob, That's the one, now to find a supplier in the USA. This version is a little bit more exotic than the ones I have seen but it is the right thing, thanks. Peter. |
John that newguy (199.232.244.9)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 10, 2004 - 6:15 pm: | |
Didja' check the local women's lib associations? (tee-hee) |
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 10, 2004 - 7:37 pm: | |
I was told they were called "Honeymoon Pliers". Don't have a clue as to why........... LOL. Peter. |
mel 4104 (216.148.246.70)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 10, 2004 - 7:59 pm: | |
they are called a Halerman tool and were used by the telephone equipment installers to put rubber sleeves overthe ends of electical power wires like battery cables this prior to heat shrink sleeves one of the larger telephone offices might still have on laying around in their tool crib. or as stated try a vet. that works on cattle or sheep some farmers used them but they are a different type. |
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 8:17 am: | |
I think this tool begs the question "why would anyone want it?" Richard |
TWO DOGS (63.185.81.238)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 9:01 am: | |
The sheep damn sure didn't |
John that hellermanguy (199.232.240.75)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 10:23 am: | |
Here: http://www.hstech.org/howto/sound/mics/head_worn_microphones.htm Hey TD, How'd ya' get the sheep to stand still? (oh. never mind........) |
R Johnstone (Chilebrew) (67.235.101.49)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 11:18 am: | |
Read this one while taking a sip of coffee---ensuing eruption: coffee all over keyboard, desk, shirt. |
TWO DOGS (63.185.80.145)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 1:13 pm: | |
I whispered sweet nothins to 'em |
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 1:58 pm: | |
Still can't find a supplier in the USA. Maplin had a reference or two, but they were discontin'ewe'd....... (ram, sheep, lamb, ewe....... Oh, never mind!!!) Peter. |
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 2:40 pm: | |
are you lookin' for the elec. one or the vet one ?...I can get you the vet thingy...was in town this morning...don't know about AZ. ...do you have T.S.C. (tractor supply company) or GEBO's farm supply,... |
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 2:49 pm: | |
JOHN.... on the ewes....ya' put one hind leg inside each of your boots |
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 2:54 pm: | |
then,....I usually start out with: "what's a nice ewe like you doing in a place like this" |
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 3:02 pm: | |
Two Dogs, It's the electrical one I am looking for, I would not feel safe with the other one around in case the wife snuck up on me one night......... LOL. Peter. |
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 3:26 pm: | |
THE BOBBIT SYNDROME.... don't get mad madbrit...but whats wrong with shrink tube...with a heat gun from harbor freight...nice ,tough wireing job... |
John that Baaaa-AAaadguy (199.232.240.75)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 3:46 pm: | |
Td - Uh-huh! Nice! So the cowboy goes out to seek his fortune on the frontier of the old West. He finally settles on a ranching town near the very edge of civilization. So near, in fact, that there aren't any women to be found for love nor money. Well, he's young and full of hormones, and after a month, he starts getting randy, so he goes to the saloon to ask around. After a couple of sort of nervous, whispered conversations, it comes out that you use the sheep. Well, our hero isn't real happy about this, but he's really desperate. He buys a bottle to nerve himself up. He goes and finds the nearest flock, and decides that if he's going to do this at all, he's going to do it right. He spends most of the afternoon picking out the prettiest sheep in the flock. He shampoos her wool and ties ribbons around her neck. Puts a little bell on her collar. He's also getting pretty drunk. By evening, he's done cleaning up the sheep, and not thinking real clearly. He's so proud of the way the sheep looks, he decides to take her in to town and show her off at the saloon. He walks in with the sheep, and the room goes quiet. Everybody's staring at the guy. And not just staring, but kinda recoiling in shock and horror. He's ashamed, but he's drunk enough; he slurs out, "Whassamada, I thought ever'body went out to the sheep?" Finally, one old timer pipes up. "Yeah, boy, but that's the Sheriffs's girl." |
John that newguy (199.232.240.75)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 3:51 pm: | |
A farmer buys several sheep, hoping to breed them for wool, chops, etc... After several weeks, he notices that none of the sheep are getting pregnant and phones a vet for help. The vet tells the farmer that he should try aritifical insemination. The farmer doesn't have the slightest idea what this means but, not wanting to display his ignorance, only asks the vet how he will know when the sheep are pregnant. The vet tells him that they will stop standing around and will, instead, lay down in the grass and roll around when they are pregnant. The farmer hangs up and gives it some thought. He comes to the conclusion that artificial insemination means that he has to impregnate the sheep. So, he loads up the sheep into his truck, drives them out into the woods, has sex with them all, brings them back and goes to bed. The next morning, he wakes up and looks out at the sheep. Seeing that they are all still standing around, he concludes that the first try did not take and loads them into the truck again. He drives them out to the woods, does each sheep twice for good measure, brings them back and goes to bed. The next morning, he looks out at the sheep and finds that they are all still standing around. He decides to try one more time and loads them into the truck, drives them out into the woods, spends all day shagging the sheep, brings them back and falls into bed, exhausted. The next morning, he cannot even get himself out of bed. He asks his wife to look outside and tell him if the sheep are laying in the grass. "No", she says, "they're all in the truck and one of them is honking the horn." |
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 4:40 pm: | |
Wyoming...where the men are men and the sheep are scared |
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 4:49 pm: | |
Sheep aren't scared, but the correct term is that they are "worried". Peter. |
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 4:51 pm: | |
I need the tool for the sleeve expanding needed for period repair work, so heat shrink would be incorrect. Peter. |
TWO DOGS (65.179.201.124)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 5:08 pm: | |
you saw different sheep... period repair....use tampax |
Derek (Derek_L) (24.83.196.239)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 8:25 pm: | |
*dies from laughter*. |
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 8:56 pm: | |
Two Dogs, You are really bad........ LOL. |
TWO DOGS (63.185.72.83)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 10:21 pm: | |
got ta' have a little fun....one of these days...we will be dead |
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 10:27 pm: | |
Maybe not dead....and gone.... Maybe just on the lamb. |
Gary McFarland (Gearheadgary) (68.250.174.11)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 10:35 pm: | |
GROAN..... |
Bob (Bobb) (69.19.3.254)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 10:36 pm: | |
baaaaaaaahhhhhdd |
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 10:53 pm: | |
I'm a bit sheepish to post in this thread, for fear I might get roasted. |
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 11, 2004 - 11:15 pm: | |
Peter, what'cha doin the resto on? Gary |
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, September 12, 2004 - 2:02 am: | |
Hey Bob, Now don't you go talkin' dirty to me......... LOL. Peter. |
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, September 12, 2004 - 2:04 am: | |
Gary, A neighbor of mine is needing it for some project he is doing and he is not a computer nut. He still lives in the tube age. I remembered a neighbor back in England having one and so that's how I got involved. Peter. |
Bruce Henderson (Oonrahnjay) (207.48.146.62)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 14, 2004 - 10:46 am: | |
Peter asked "Does anyone have the correct name for the following tool description " __. Yeah, what the other's said. We also used them at the Land Rover works when I was there to expand grommets for wiring harnesses. You'd stretch the grommet, slide the wires through, and then hope that the grommet would snug down on the wire. If the grommet fit the wire and engaged in a metal panel, it would prevent water leaks pretty well and would stop the wiring from chafing on the edges of the hole. |
madbrit (67.136.98.250)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 14, 2004 - 10:57 am: | |
Seems that this is primarily an English tool as that is where the leads seem to go. Oh well, one may turn up someday. Thanks for all the help. Peter. |
