Roy Childs (Rchilds)
Registered Member Username: Rchilds
Post Number: 23 Registered: 5-2007 Posted From: 142.161.181.204
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, January 23, 2012 - 9:42 pm: | |
Anyone know where the activation switch is for the back-up lights on a 87, 102A3. |
Tom Christman (Tchristman)
Post Number: 356 Registered: 1-2006 Posted From: 66.218.51.7
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 24, 2012 - 1:25 am: | |
If you have an Allison transmission-it will be on the transmission itself. Good Luck, TomC |
Post Number: 24 Registered: 5-2007 Posted From: 142.161.181.204
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 24, 2012 - 11:28 am: | |
Yes it has a HD740 Allison. Thanks, I'll look in that area. |
Post Number: 1368 Registered: 8-2006 Posted From: 184.10.153.249
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 24, 2012 - 1:36 pm: | |
A 740 it will be on the drivers side close to ID plate in the middle just above the oil pan 2 wires good luck |
Ralph Peters (Ralph7)
Post Number: 209 Registered: 3-2004 Posted From: 75.226.47.176
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, January 25, 2012 - 12:43 pm: | |
It is activated by pressure only so you need it in reverse an running! It has power from the rear power panel full time that the dash switch (key), and main batt. on. I changed mine but it was good, had open to lights. |
