Johnny (4.174.91.48)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 20, 2004 - 9:41 am: | |
I don't know how I missed it (or why it's there), but I just realized I have an empty battery compartment on my bus. The start battery (a 12V Group 31) is under the "hood", on the right framerail just behind the front axle in a box. Under the driver's seat is a pull-out tray (currently empty), that appears to be sized for a pair of 8D's. My questions are: 1) Does anyone have the dimentions of a T105 handy? If I can put my house batteries here, that will greatly halp things. 2) If they won't fit (and I suspect they won't, since IIRC, a T105 is substantially bigger than an 8D), what about putting my genset on the slide? A genset can't be THAT much heavied than 2 big batteries. |
Craig Smith (Craigs) (65.202.123.254)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 20, 2004 - 12:43 pm: | |
Hi Johnny, Dimensions: 11"L x 7"W x 12"H. Weight: 61 lbs. Craig S. |
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 20, 2004 - 4:29 pm: | |
Also do not forget that you will need some more height to get the caps off and some way to water the T-105. And..if you go to "Hydrocaps", then you will also need some more height, but I do not know how much. Help here. |
RJ Long (Rjlong) (67.181.236.27)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 20, 2004 - 8:59 pm: | |
Johnny - Another possibility is to use a couple of deep-cycle 8Ds for your house system, and put them on that tray. Especially if it's already sized for them! HTH, RJ PD4106-2784 Fresno CA |
Johnny (4.174.109.203)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 21, 2004 - 1:36 am: | |
"Also do not forget that you will need some more height to get the caps off and some way to water the T-105." The tray slides out. If 11x7x12" is a 105, I should be able to do this easily. In fact, that sounds smaller than an 8D. I've never seen 8D deep-cycle's...maybe. |
FAST FRED (4.245.191.158)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 21, 2004 - 5:16 am: | |
Surette has the possably best quality 8D deep cycle batts that money can by , unfortunatly LOTS of money. An investment of that much cash should only be made with a good method of MONITORING the battery state of charge. In the archives. FAST FRED |
