Air door lock air Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » September 2004 » Air door lock air « Previous Next »
Jerry Campbell (67.21.41.198)
Posted on Tuesday, September 21, 2004 - 9:21 pm:
I took the bus out today for a ride to see how the new gen. worked with 3 airs and it was a coolride. but the air lock on the door would not work it is like no air going to the sys.Well I can not find air. have looked at the book and can not find where the air comes from. Help Thanks Jerry MCI 102 A 3
BrianMCI96A3 (65.160.215.73)
Posted on Wednesday, September 22, 2004 - 12:12 am:
Jerry, if your 102A3 is like my 96A3 (and probably like an MC-9) the electrically operated air solenoid for your air lock is located under a panel on the upper section of the left stairwell wall, behind that panel is a small compartment that is just under the floor and just behind the air lock itself.
Brian
Jack Conrad (Jackconrad) (207.30.189.33)
Posted on Wednesday, September 22, 2004 - 7:10 am:
Jerry,
Is there a small lever with a red plastic knob on the end under the dash above the throttle pedal? If so this is an over-ride switch. At least this is the way our MC-8 was set up. Hope this helps, Jack
Jerry Campbell (67.140.252.55)
Posted on Wednesday, September 22, 2004 - 7:50 am:
Jack I have no air to the over ride.
Posted on Wednesday, September 22, 2004 - 8:07 am:
We removed all this from our MC-8, but if I remember correctly the air supply was the accessory tank that is mounted under the drivers seat. The air goes to a regulator, then to a solenoid,through the override switch and then to the air lock cylinder. The solenoid is controlled by a micro switch installed on the lower part of the door crank that is on the dash. You might try cracking the line that enters the solenoid to see if you are getting air there. If you are, check for air after the solenoid. All of these components are located in the top of the spare tire compartment (at least on our MC-8, that is where they were). Hope this helps, Jack
PS: One other thing I happened to think of, Check for power to the solenoid.
Posted on Wednesday, September 22, 2004 - 12:08 pm:
I found it> It was the switch under the dash thanks Jerry
