Air bag/Prevost question Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2012 » February 2012 » Air bag/Prevost question « Previous Next »
Username: Ace
Post Number: 1390
Posted From: 166.248.77.95
Posted on Friday, February 10, 2012 - 10:44 pm:
Below is a link to picture of two air bags. The old is upside down on top of the new one to show a comparison if the mounting stud length differences. It's about a 1/2 inch difference and after being on the phone about a half a day, Prevost says these are the correct bags that superseeded the original!
Sure they fit but the stud doesnt allow for a washer to be used and the nut only goes on far enough that still shows about a thread to a thread and a half. In other words, the stud doesn't even come to the end of the nut!
Has anyone else seen this as a problem? These are Goodyear bags with a Prevost part number 630259.
http://i1203.photobucket.com/albums/bb394/Goldbus/0a2f5085.jpg
Post Number: 2268
Posted From: 174.91.142.183
Posted on Saturday, February 11, 2012 - 4:53 am:
The fasteners really just hold it in place, not a whole lot of force involved in that regard.
Anti-corrosion goop of your choice on assembly.
Username: Chessie4905
Post Number: 2254
Posted From: 71.58.71.157
Posted on Saturday, February 11, 2012 - 8:24 pm:
is that base cast? Some bases can have the stud removed and install a longer one. Maybe the mounting area on newer models is thinner.
Username: Ace
Post Number: 1391
Posted From: 166.248.64.86
Posted on Saturday, February 11, 2012 - 9:33 pm:
The base is steel and only has mounting holes. The bags have studs that non removable!
Bill Gerrie (Bill_gerrie)
Username: Bill_gerrie
Post Number: 642
Posted From: 216.198.139.38
Posted on Sunday, February 12, 2012 - 12:07 am:
Ace
When I replaced my air bags they came with a thin stamped steel nut. Just holds them in place. I wouldn't be too concerned.
Bill
Post Number: 2255
Posted on Sunday, February 12, 2012 - 3:23 pm:
if you need thinner nuts, You could among others, try McMaster-Carr. Since there is always pressure in the bags, hopefully, there is no force trying to pull bags loose, unless shocks are disconnected. The ones you have should do fine, even without full threads engaged, since you have as many as a thinner nut.
