Darrell Black, DVM (Darrelldvm)
Registered Member Username: Darrelldvm
Post Number: 68 Registered: 6-2005 Posted From: 72.4.181.208
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 28, 2012 - 11:57 pm: | |
4106: Will the 5.75 HR/HCR cibie head light fit into the original head light bucket? |
Post Number: 1899 Registered: 12-2000 Posted From: 71.195.175.142
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 29, 2012 - 4:31 am: | |
Darrell - Yes, but you may have to modify the back of the bucket to accommodate the larger bulb. Highly recommend that you update the wiring and plug (available from most auto parts houses) to handle the extra load. Use a relay so that the headlight switch only sends trigger voltage to the relay. Once you get these installed and aimed properly (that's REAL important!!!), you'll be absolutely amazed at how effective these lights are. BTDTHTS!! FWIW & HTH. . .
L James Jones Jr (Jamo)
Post Number: 248 Registered: 11-2007 Posted From: 74.71.202.151
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 29, 2012 - 6:55 am: | |
What's a cibie light? If they are that good, do they make single light app's as in 4104's?? |
Brian Evans (Bevans6)
Registered Member Username: Bevans6
Post Number: 138 Registered: 5-2009 Posted From: 207.164.79.20
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 29, 2012 - 8:41 am: | |
Cibie is a brand of automotive head lamps manufactured in Europe that are known for excellent optics, tightly focused beams and over all high quality. http://www.danielsternlighting.com/ Brian |
Post Number: 1477 Registered: 11-2005 Posted From: 173.202.29.43
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 29, 2012 - 5:09 pm: | |
Brian, You left out the outrageous prices. I've tried some of those European lights, including Marchal, and found them not worth the money. Plain ole US halogen HL work just fine for me. I found some at NAPA for $12 that are sealed beam with a bulb inside so when the lens cracks the lights still work. |
Post Number: 1900 Registered: 12-2000 Posted From: 71.195.175.142
Rating: Votes: 1 (Vote!) | Posted on Wednesday, February 29, 2012 - 6:21 pm: | |
James - Yes, Cibie does make the big 7" lamps to fit your 4104, and, IMHO, they are well worth the money. I know Gus doesn't agree due to the cost issue, and that's fine, to each his own. I've used them since the '60's, and even tho today's headlamps are a big improvement over those from that era, the US-spec lamps still do not have the tightly focused beam pattern of the European code (E-Code) lamps. The $12 halogens from NAPA still produce annoying glare to oncoming drivers, because the optics of the lens are still US spec. The only difference is that they're brighter. Yes, they're expensive, about $75 per lamp or so. Plus whatever you need to do to your coach's headlamp circuitry to upgrade to relay-operated lamps. I've found pricing to be a little better at the importer's site: www.cibieusa.com Daniel Stern's site, however, gives a really good explanation of the differences between the US DOT-code and the E-code optics, well worth reading. When folks complain about the cost, I always ask "What price SAFETY?" FWIW & HTH. . .
