Electrical help Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » October 2004 » Electrical help « Previous Next »
mclough (63.235.52.225)
Posted on Friday, October 08, 2004 - 8:54 am:
hey guys( and gals)
i have a 4104 with the fiberglass converstion kit on front. the problem is the previous owner did not wire up the front directionals/ parking lights. where do i connect them to?
thanks in advance and thank you to all whom have helped me, this site has helped me a huge amount.
morgan
www.outreachacrossamerica.com
J.L.Vickers (209.169.106.163)
Posted on Friday, October 08, 2004 - 9:23 am:
The electrical panel on the left side of the drivers compartment(under large panel that you remove to gain access to)
Terminal #24 left front turn siginal.
Terminal #64 right front turn siginal.
Run new wires from each turn siginal to the correct terminal.
There were no front parking lights on the 4104 just top corner markers and center clearance light front and on the rear you had tail lights and clearance lights and corner markers.
Hope this helps.
J.L.Vickers
Marc Bourget (209.142.38.81)
Posted on Friday, October 08, 2004 - 9:27 am:
Morgan,
DA Book (Chassis/Parts) for the GM should have a wiring diagram, which will tell you. These books are something you should have for reference. What they won't talk about is the fiberglass.
I suspect (RJ, are you there?) that the original setup used the chassis for ground. This won't work with the fiberglass front and you'll have to ground to chassis, or back to switching device (best, but uses more wire) If you ground to chassis, make it "good" and ensure it stays dry, finally, make sure you have future access, cuz a host of electrical ills all seem to devolve back to grounding problems. This is so because them pesky electrons will seek a ground path through other electrical devices, disguising what the real problem is. Very difficult to diagnose, sometimes.
Onward and Upward
mclough (65.137.130.167)
Posted on Friday, October 08, 2004 - 12:32 pm:
thank you J L this should be an easy fix. what are the yellow lights on the fron then just under windshield? shouldnt they be original turn lights.
Posted on Friday, October 08, 2004 - 2:39 pm:
Yes the amber lights under the windshields at each corner are the original turn siginals.
Greyhound PD4104's had seal beam amber light bulbs
I still remember the numbers
4414A amber
4414R red
They were avaliable through NAPA.
J.L.Vickers
mclough (65.141.114.170)
Posted on Friday, October 08, 2004 - 4:02 pm:
hey JL
do i want to hook those yellow amber lights as markers or as parking? right now they are tied into the amber turn lights but dont act as parking. what do you think? is thier a way to make them both parking and turn?
thanks
TWO DOGS (63.185.97.100)
Posted on Friday, October 08, 2004 - 5:01 pm:
nope....the markers are supposed to be hooked to your light switch
Posted on Friday, October 08, 2004 - 9:48 pm:
Amber lights are the turn siginals.
PD-4104's from the factory did not have front amber parking lights.
They only had amber front corner marker and clearance lights.
J.L.Vickers
