Frank Allen (66.26.215.113)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, July 09, 2001 - 3:32 pm: | |
There is a electricheating element or coil or whatever you want to call it, id take a volt meter and check to see if it is getting the voltage, you can sisconnect the wires going to it then check accross the coil with a ohm meter, if it shows 0 replace the coil, if its got the voltage present, and the coil is ok it has to work, could be a fuse somewhere blown. see where it feeds from . should be easy TO check out, hope all this helps you out Frank allen |
