pete hyser (4501pete)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 15, 2004 - 6:17 pm: | |
ok call me whatever you want but i have an oil pan question about a 8-71 there are 2 small bolts and one plug looking bolt. Mine..well...this is pete your talkin to so its rounded, locked up and it aint movin. The 2 screws are draining oil...i know its going to take a while but is this kosher? also.. where the hell is the oil filter? pete |
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 15, 2004 - 6:27 pm: | |
oil filter is on drivers side,back at the back,big ol' thing heavy when full of oil.,you might need one of those strap wrenches to get it off.....the plug,...doesn't sound right...who knows what the last guy did,the big one should come out,sounds like you need a new one.. |
Jayrjay
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 15, 2004 - 9:21 pm: | |
Hey two dogs- I've got a hundred dollar bill says you can't get my oil filter off with TWO strap wrenches, and besude that, Charile's is two feet long and on the passengers side. Both are 8V71's and stock DD filters systems. Now what? ...JJ |
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 15, 2004 - 10:10 pm: | |
how does the comercial go...........sorry charlie |
Gary McFarland (Gearheadgary)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 15, 2004 - 10:36 pm: | |
"Charile's is two feet long" Doesn't sound like he needs to be sorry.... Gary |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 16, 2004 - 6:52 am: | |
ok then pan is empty..i got full..{beer} nut aind going anywhere but those screws did work. I should have done this alot sooner but im on a mission to try to slow down all the oil leaks i have..yea yea yea i know..its a dd..but after looking and tightning the pan, the only thing i cant really tighten is a head gasket..other then that theres going to be alot less erl in my driveway pete |
BrianMCI
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 17, 2004 - 12:39 am: | |
I've only had a few oil filters really give me grief over the years... After a few minutes of struggling with a strap, a large pair of channel locks come out and usually that does it...even if the filter gets mangled. But every once in a great while even that doesn't do the trick... I pull out a big screw driver and a mallet, stab that bugger straight through and using the screwdriver as a lever, off it comes! Yessir a big screwdriver and a mallet to hammer it home, works EVERY time. Brian |
RWC
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 21, 2004 - 7:55 am: | |
I did the screw driver and mallet thing once and wound up tearing filter apart with threads still in housing. Judicious use of chisel finally solved that problem. |
