Stainless buffing swirls Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » November 2004 » Stainless buffing swirls « Previous Next »
CTMcswain
Posted on Monday, November 15, 2004 - 7:16 pm:
How do you get the tiny swirls out of stainless ? I have tried using the 3M foam pads but they did not cut . The wool pad will cut but leaves small swirls that you see if the sun is just right.
Kevin Allen, Nebus (91flyer)
Posted on Monday, November 15, 2004 - 7:44 pm:
First off... remember that when you're polishing something, you are actually creating finer and finer scratches... so, first rule of thumb is DON'T use a power buffer.... instead, use straight line hand buffing, and go with the body lines. I've used a product called Mother's with some degree of success, but I know there are better products out there that work better...
Also, with steel wool pads (best in my opinion for stainless and chrome -- never used it on aluminum before), the same rule applies... no circular motions... straight lines.
-Kevin
Posted on Monday, November 15, 2004 - 8:16 pm:
you have put big scratches in the stainless...now you have to make the scratches smaller,go to a sheepwool pad and use rubbing compound,then use a good wax,like mothers
John that newguy
Posted on Monday, November 15, 2004 - 9:58 pm:
Doesn't anyone use Bon Ami anymore?
Don/TX
Posted on Monday, November 15, 2004 - 11:58 pm:
Or to make it all simple, just use a finer and finer polishing compound. As I recall, you should finish it up with tripoli. Power buffing does NOT leave any marks at all if you use the right compound.
