captain ron
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 16, 2004 - 5:24 pm: | |
I started my bus today for the first time in a week. it galloped for a while like it usualy does when it's cold then smoothed out. then it started vibrating and quit. I still have fuel about 40 gals. It's been cold down in the low teens. any ideas where to look first. It acts like its out of fuel. does deisel gel in that type of weather? I need to take it on a road trip fri. |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 16, 2004 - 5:27 pm: | |
doesn't gel till about zero...have you had any kids in your bus...maybe the mouse trap has been tripped... |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 16, 2004 - 6:15 pm: | |
second guess would be a stuck injector |
jimmci9 #2
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 16, 2004 - 7:22 pm: | |
#2 diesel will "cloud" at about 35 degrees farenheit... clouding is the parrafin showing up.....that's present in all diesel.... you may have a lot of water in the water separator... water freezes at 32...check your filters... |
John Rigbyj
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 16, 2004 - 8:19 pm: | |
What type of bus and engine?? |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 16, 2004 - 8:36 pm: | |
4905....8v71 LH |
John that newguy
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 16, 2004 - 9:45 pm: | |
Man..... "It's been cold down in the low teens. - It acts like its out of fuel. does deisel gel in that type of weather?" Yeah. Sounds like jelled fuel. Ya' got a space heater and a lot of time? And..... a nice heat gun to aim at the filters? With our old Mercedes, Volkswagon(s), and Peugot(s), we added some of the great gas line anti-freeze... and a gallon or two of gas to the diesel fuel. Maybe someone here can say if that's OK to do with a 2 stroke? I don't see why not... But hey.. |
abcdefg
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 16, 2004 - 11:19 pm: | |
Sounds like it ran out of fuel. There's probably an air leak in the line someplace and your fuel drained back to the tank while sitting. Reprime it and try again. |
Johnny
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 16, 2004 - 11:28 pm: | |
DON'T add gas. To prevent gelling, add K-1 kerosene--I usually use about a 10-15% mix at the most. |
Lin
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 17, 2004 - 2:38 am: | |
I have never had my bus in cold climes so do not know what contribution that could be making. I did once have a similar starting problem that turned out to be a cracked fuel line that allowed air to be sucked in. |
John that newguy
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 17, 2004 - 7:45 am: | |
From: http://dodgeram.org/tech/dsl/FAQ/cold_wx.htm ---------------------------------------------------------- Q: Should an additive be used in the fuel to keep it from clogging the fuel system? Below 15 degrees F, wax crystals begin to form in diesel fuel. These crystals form a gell that will clog the fuel filter or fuel lines and stop the engine as the temperature drops toward 0 F. Any good "winter fuel conditioner" for diesel fuel will keep the fuel moving to at least -20 degrees. Follow the instructions on the bottle! Q: How can I tell when the fuel begins to gell? The first hint is often an unstable idle. The idle speed may increase to 1000 rpm or more and fluctuate slowly. Next the engine will begin to lose power. Within a few minutes the engine will quit and not restart or will only restart briefly. Q: What can I do if the fuel has already gelled due to the cold? The time proven remedy is to add a gallon of kerosene for each 10 to 20 gallons of fuel to the tank, then allow it to sit long enough for the kerosene to diffuse into the fuel. In weather below -20 degrees F, one gallon of kerosene for 10 gallons of fuel will keep things moving, but fuel economy will be reduced. Kerosene now has red dye which a DOT inspector will assume is off-road diesel. Be prepared for a hassle if you are checked. Apply heat to the fuel filter to break up the wax. ------------------------------------------------------------ With only 40gl in the tank and temps in the teens... It should be real safe to assume the fuel's jelled. |
Bob Oakman (Bobsbus)
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, November 18, 2004 - 1:01 pm: | |
I have the 8V-71 as well... I'm lucky I guess. I did all the fabrication on my bus in Northern Minnesota... during the winter. The temperatures were below zero most of the winter. I would heat the garage while I was there working on the bus, but most of the time it sat in the cold. It always started and ran perfectly, even the times I started it in the cold to back it out. Kansas, the previous april, was the last place i had fueled it. I doubt there was any additives in the fuel. After reading this thread, I am amazed that I had no trouble. I had some trouble with frozen water in the air lines, a learning experience, but she ran real good. |
