How can i dispose 100 gallons of old ... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » November 2004 » How can i dispose 100 gallons of old diessel « Previous Next »
Gelecamion (Gelecamion)
Posted on Saturday, November 27, 2004 - 10:04 pm:
hi gbusnuts this is gele i have to drain
100 + gallons of diessel its been sitting in mine 4104 for 5 years but i donot know what to do with it please help is there a company that cames to site and pumpsthe old diessel out for a fee?
thank you
GEle in tucson
Bill K.
Posted on Saturday, November 27, 2004 - 11:26 pm:
Try some one with a waste oil furnance.
frank-id
Posted on Saturday, November 27, 2004 - 11:27 pm:
For your problem there are several solutions. Bring the fuel to me, pump half fuel into a oil drum, and add Power servive, or just drive baby drive. I have known several bus guys who used diesel fuel oil that was 8 , 6 and 5 years old with no problems. Calling some one in the yellow pages will get rid of your fuel. Call the big truck freight companies. Boy, I wish I lived closer.. Frank in Idaho
Posted on Saturday, November 27, 2004 - 11:57 pm:
Gelecamion, buy some extra fuel filters and use it to get your bus down the road.
If you are really concerned about junk in the tank, get a couple or three 55 gallon drums to hold the fuel and drain the bottom of the tank into the last one.
If you don't get serious crud from draining the bottom of the tank, the fuel in the 55 gallon drums ought to work fine. Letting it settle a few days or a week will clear up the stuff on top.
Only put clear fuel back in the tank. What's left you might be able to turn into a bulk plant or other fuel supplier.
Good luck.
Suncatcher
BrianMCI
Posted on Sunday, November 28, 2004 - 12:17 am:
First smell the fuel, and if it smells like diesel, I'd say it's good to go.
Brian
Posted on Sunday, November 28, 2004 - 5:07 am:
Purchase 500 8oz bottles and get some labels ,
FUEL IMPROVER for better milage.
or..
OIL ENHANCER , solves cold start problems.
At $5 a bottle you should be rid of it in a week.
No comission , thanks!. I stole the idea from
Mystery Marvle Oil, Dura Lube And Slick (it into my wallet) 50.
Reasonably ,If you can drain it and filter it to get the bugs water and ashphalt clumps out , its OK to burn.
Gary McFarland (Gearheadgary)
Posted on Sunday, November 28, 2004 - 9:53 am:
As the others have mentioned, Diesel is very stable. pump it into drums and seal it up. When you are ready to use, you can pump it through a Racor or similar filter back into your tank.
Gary
mel 4104
Posted on Sunday, November 28, 2004 - 11:44 am:
as you live in the Tuscon area you should have no trouble with the fuel , just dip the tank with a stick then see if there is any thing on the stick other than deisel and if it still has the strong smell of deisel just fill up the tank and run it through yor engine, and when the tank is enpty change the filters and refill the tank . we started a ore truck green valley that had sat for 12 years with the fuel in the tank and it ran great and when the filter was changed they onlf had the normal little bit of junk.
neomax
Posted on Sunday, November 28, 2004 - 1:37 pm:
That's good FF! Sort of like "WatrWetter" (25% Ethylene Glycol and 75% inert ingredients: water maybe, at $7.00/qt.)
Johnny
Posted on Sunday, November 28, 2004 - 6:56 pm:
Anyone who knocks Water Wetter has never tried it. Without it, if I set my de Ville's cruise control at 75, turn on the A/C on a 90-degree day, & go up a few hills, the engine overheats. With Water Wetter, it runs hotter than I'd like it to (~220), but doesn't boil over.
Results in my friend's Buick SkyHawk were similar: summer highway driving saw a 10-15 degree temp drop. Water Wetter very simply WORKS.
Posted on Sunday, November 28, 2004 - 8:38 pm:
Water Wetter is simply detergent. It, by itself, doesn't have Ethylene Glycol.
Water Wetter reduces water's surface tension. You can get the same result with dish soap.
Onward and Upward
Johnny
Posted on Sunday, November 28, 2004 - 9:02 pm:
Whatever it is, it works.
Posted on Monday, November 29, 2004 - 4:08 pm:
Seriously, try your local fuel wholesellers. Bet they will PAY YOU something to come get it. Lots of uses for it after filturing. Good luck.
gg04
Posted on Monday, November 29, 2004 - 4:28 pm:
Really don't know of any part of the country where you can't find someone to come out and polish your fuel if your really worried about it.Normaly cheaply done and then you have nothing to worry about. gg
